New Samsung mobile phone charger lead help required
HelloDuck
I have just purchased a new Samsung mobile phone and the end of the charging lead which goes into the bottom of the phone is quite a lot wider than normal with two connections never seen one like it before
Is this because it's a fast charger what is the lead end called
Can this lead be used with a USB in a 13A wall socket
HD
11 REPLIES 11
idonno
Champion
Fixes: 6
Re: New Samsung mobile phone charger lead help required
A picture would help but I suspect the wider connector is a USB-C micro connector (the wife's relatively new Samsung and my Moto phone have the same USB C ports). Maybe the charging lead, if it has 2 connectors, does old and new.
And yes, if you have a USB cable, plug it in to the USB socket. FWIW the phones tend to tell you if it will be charging quickly or charging slowly when you plug them in. Just takes longer if not quick.
Edit: To light up your day you could always get an LED charging cable, something like this, maybe
Ever helpful. Grin Sure, I’d love to help you out. Now which way did you come in?
HelloDuck
HelloDuck
These are  the photo's of the lead end
HD
idonno
Champion
Fixes: 6
Wow, never seen the likes ... good luck in your quest for knowledge! 😃
idonno
Champion
Fixes: 6
What Samsung phone model you got?
Just a thought, are both sides of that plug fixed or do they slide in independently?
HelloDuck
Hi
Both sides are connected to each other a fixed push in connector
The phone is a Samsung Galaxy Note 3  SM  N9005  Single Sim
HD
SteveA
It's quite an old phone - the USB end should be fine in a standard Mains/USB adaptor but not a Mains/USB Fast charge.
Fixes: 187
Its a USB3 micro B
https://en.wikipedia.org/wiki/USB_3.0
Strat
Fixes: 514
The end shown in the photo is of a USB3 cable.
I have one on my Maxtor external hard drive.
Customer and Forum Moderator. Windows 10 Firefox 89.0.1 (64-bit)
HelloDuck
Thanks to everyone all sorted its a USB 3.0 A To Micro B Cable
You learn something new everyday
HD
billnotben
I briefly had an s5 with a lead like that. I could either use that lead which I found a bit clonky or simply just use a normal micro usb cable. Which obviously just used the one (correct) port on the phone.
