Netflix USA
Jonathan1988
Netflix USA
Hello~!
I've just signed up for Netflix and I'm using a VPN to access content in the states however the quality is really bad probably even below SD at times.  Is this to do with poor download speeds because I'm connected to a Washington IP address and thus nothing I can do about quality?  Is it even okay to use a VPN in this way?  Embarrassed  [/possibledumbquestion]
Fixes: 62
Re: Netflix USA
Unless you have the Pro add on the speeds will be heavily restricted on VPN in the evenings on Extra and you can forget about Value http://www.plus.net/support/broadband/speed_guide/download_speeds.shtml
Jonathan1988
Re: Netflix USA
That would explain it.  Thank you.
