Need Help, Please Help - [ Problem is back ]
Midnight_Caller
Hi All
Please test the following Domains:
http://www.dyslexia.f9.co.uk
http://www.dhea.org.uk
http://www.dhea-forum.org.uk
I am getting for: http://www.dhea-forum.org.uk
http://homepages.force9.net/dyslexia/403.html
Plus
I am getting for: http://www.dhea.org.uk
and
Wen using a Proxy Server I am getting: 404 Error
I asked PlusNet to Downgrade the tdadyslexia account to Dial-up,
But It Looks like they Downgraded both of my accounts.
198kHz
All Star
Fixes: 10
Re: Need Help, Please Help
All three OK for me , Gary.
Remember you are unique - just like everyone else
Fixes: 100
Same here...ok.
Customer and Forum Moderator.
Fixes: 193
The page isn't redirecting properly
          Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
  This problem can sometimes be caused by disabling or refusing to accept
    cookies.
for all three, sorry Sad
Cookies enabled.
Forum Moderator and Customer
Fixes: 10
All of them work for me too.
Midnight_Caller
@4C, @Strat, and @Sprite Thank you for checking, are you on a PlusNet conexion?  If Yes do you have access to a different conexion?  To test
@Mav, Are you on a PlusNet conexion?  Thank you for testing out the Domains
http://www.dyslexia.f9.co.uk  works but the 123-reg fails to display
http://www.dhea.org.uk  works fine ..........nice touch with the background colour select
http://www.dhea-forum.org.uk  works fine
all with IE9, PN connection
Fixes: 10
Quote from: Midnight
Yes I'm on plusnet. Givee me a jiffy I will try via my dongle on three.
Fixes: 100
I have just tested the sites on my phone connected through T-Mobile and the are ok.
Midnight_Caller
Thank you journeys for testing them
@Sprite, Thank you
[Edit]
@Strat, Thank you
Fixes: 193
No - I'm on a TT connection.
Fixes: 10
All good on the 3G dongle too Gary.
No need to worry it must be your connection.
198kHz
All Star
Fixes: 10
Yes, on Plusnet - but using BT DNS. No other access available.
Fixes: 193
I'm using Google's DNS (8.8.8.8 & 8.8.4.4)
Midnight_Caller
Thank you Mav, like you I am not on a PlusNet connection, I'm on a NTL / Virgin Media connection.
[Edit]
Now working on NTL and 3G dongle
Not working on 3G dongle
But is now  working on NTL  Huh  Huh
