Monitor Clean
Strat
Fixes: 506
Monitor Clean
A few weeks ago I decided to clean my monitor as there were a few marks on the screen.
Out came a damp cloth and I gave the screen a good wipe over which did the trick....except one tiny mark.
It did look like a dead pixel but strangely enough it moved.
Assuming it was a tiny insect, no more than a millimetre long, I wiped the area once again, a little more firmly.
It was then that I realised the insect was between the LCD panel and the transparent front.
Not a good place to be if you are claustrophobic.
It is now no longer in the land of the living.
Customer and Forum Moderator. Windows 10 Firefox 88.0.1 (64-bit)
11 REPLIES 11
twocvbloke
Re: Monitor Clean
Those are annoying bugs when they get inside of LCD panels, though when you have a whole infestation of them, yeugh!!!!! 🤢
7up
Fixes: 14
Re: Monitor Clean
The greenhouse is the same - the windows are made of plastic that is corrugated like cardboard. Naturally a few insects get in there and then get stuck leaving it to look ugly..
Darn thing is also a magnet for spiders. I won't even go in there now.
198kHz
Fixes: 31
Re: Monitor Clean
So you ended up with a screen resolution. Laugh
The older I get, the earlier it gets late.
ADSL2+   Billion 7800N
Jonpe
Fixes: 9
Re: Monitor Clean
How many pixels to one insect?  You might have invented a new unit of measurement.
Strat
Fixes: 506
Re: Monitor Clean
@Jonpe squashed or non squashed?
I would say 1 pixel per bug un-squashed and 2 pixels per bug squashed.
198kHz
Fixes: 31
Re: Monitor Clean
Being visible, they should be easier to find than software bugs.
Alex
Fixes: 12
Re: Monitor Clean
Yep round my sisters house I noticed a line of dead pixels near the middle of the screen.
So I asked about it, it turns out my niece had poked it. Hence the problem.
One new TV later, all fine. Feels like I am getting old now, but you could do that with an old school CRT.
twocvbloke
Re: Monitor Clean
Unless they're Microsoft Bugs, they're huge... 🤣
198kHz
Fixes: 31
Re: Monitor Clean
The PN billing system bug must be visible from space.  😉
RobPN
Fixes: 5
Re: Monitor Clean
I would think @Strat removed the software from it when he squashed it, which may even have made it more visible.
Jonpe
Fixes: 9
Re: Monitor Clean
Perhaps that's the millennium bug everyone was talking about; it got stuck in your screen and that's why the planes didn't fall from the sky.
