Mobile phone codes...
Someone sent me a short while ago a list of useful dial codes for mobile phones, that included a code to get at the extra battery life -for emergency purposes- that is actually stored in a battery (presumably that which retains memory etc.) but for a very short period, it could be useful to be able to access it. Does anybody know any of them...cos' I couldn't arf' of used it earlier today!!
Re: Mobile phone codes...
It's twaddle.  Crazy
See here for an explanation: http://www.snopes.com/inboxer/household/cellphones.asp
Fixes: 13
When you key that in, do you use upper or lower case, for it to give you extra battery power in emergency? Roll eyes Roll eyes
