Mobile Phone Coverage
http://www.bbc.co.uk/news/business-14574816
The BBC reports that the 3G coverage of the UK might not be as good as the mobile phone companies proclaim.
Now Zen, but a +Net residue.
Fixes: 260
Re: Mobile Phone Coverage
Indeed, at our offices on the 4th Floor in the middle of London there is awful 3G coverage, no matter which network you're on in which I find crazy.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Yep, this map kind of confirms what the majority of us already knew and the phone companies also knew but would not admit!
For those in the rural locations, this map shows the idea that 3G can replace ADSL is just not going to happen without more basestations being installed!
3Mb FTTC
An interesting report.  Saw the item on BBC Breakfast this morning. 3G is certainly not good even in rural areas.
Here's the map to enter your postcode and check your area:
Coverage
What I don't understand is when I enter my postcode and look at 'all' my area is solid 2G.  When I look at my supplier only,O2, it shows 3G which is what I can get. Undecided
Fixes: 144
In the street outside my local Morrisons there is a T-Mobile mast.
Inside Morrisons my T-Mobile phone says 'no signal' Undecided
Customer and Forum Moderator. Windows 10 Firefox 62.0.3 (64-bit)
gswindale
Interestingly I tried to take part in that survey; but my Android device was not compatible :-(
