Mobile Banking
Fixes: 101
Mobile Banking
I've happily done my online banking with LloydsTSB using my PC for quite some time now with no problems.
I have now received an email from them advising me they have on offer an app for my Android phone enabling me to continue my online banking into the street and beyond.
For some reason this fills me with dread, not simply because my phone could be lost or stolen but also because I consider it much less secure.
Does anyone here do mobile banking and what are their experiences.
Customer and Forum Moderator.
Re: Mobile Banking
@Strat, I'm with you on this one.  I use LloydsTSB for online banking but wouldn't fancy extending it to my mobile Sad
Fixes: 224
Re: Mobile Banking
I too am with the Lloyds-tsb and have downloaded and installed the app. It's ok but I don't think I'll use it regularly.
As long as you don't tick the remember me box it should be as secure as using your PC.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Steve
Seasoned Pro
Re: Mobile Banking
I have done a fair bit of mobile banking in the past, Usually clear my cache and cookies once I am done, Nothing dodgy happened to me so far ( Touch wood ) Huh
If life gives you lemons, make lemonade.
Re: Mobile Banking
Slightly different but the same thing if you see what I mean. A while ago my phone service provider "gave" me a laptop dongle so I could access the internet on the move via their service. Telling me it was useful to be able to do mobile online banking if I wished. I've never used it.
