Missing Icon
Missing Icon
What has happened to the 'members centre' icon on the PN homepage? It seems to have disappeared.
3 REPLIES 3
Fixes: 80
Re: Missing Icon
Is it the main navigation at the top of every plus.net site? If so, it has been changed to 'My Account' and you can login to the seperate account pages for member centre or mobile. If you click the 'My account' link it will take you to an option page to choose between the regular member centre or the mobile account page.
There is also a link directly to member centre on the homepage of plus.net, its on the far right of the 4 columns under the main banners.
Re: Missing Icon
@jaread83 thanks. Yes that's the one.
Fixes: 80
Re: Missing Icon
The change to the main navigation came down to all of your help on this thread: https://community.plus.net/t5/Plusnet-Feedback/Help-us-improve-the-Plusnet-Website-takes-2-minutes/m...
We tested what worked best and went with the most positive outcome of that. So thank you all for those who participated and gave us the feedback needed to make the change.
