Missed!
Missed!
pierre_pierre
Re: Missed!
cant read chines what was the story?
Steve
Seasoned Pro
Re: Missed!
Yes not good with chinese myself either,someone playing with missiles or rockets?
If life gives you lemons, make lemonade.
Fixes: 101
Re: Missed!
I can't read Chinese either but got the gist of the video. Smiley
I presume ATC had everything under control Undecided
Customer and Forum Moderator.
Re: Missed!
Apparently a military missile test in the Japan area! How far away was it? I reckon no more than five miles.
Re: Missed!
Distances are notoriously difficult to assess at those kind of altitudes. But it does look uncomfortably close!!
