Microwave light bulb
Fixes: 131
Both the Panasonic Microwave and the Whirlpool oven bulbs have died this week.
Checked the oven bulb. Just a small window to remove via a couple of screws. Standard oven bulb...no problem.
Next the Microwave. I can see the bulb but there is no apparent access to it.
Out with the manual and can't believe it I have to get a service engineer out to change it. Shocked
A service engineer to change a light bulb......are you taking the [Censored].
No way.
Customer and Forum Moderator.
Re: Microwave lightb bulb
cheaper to get a new Microwave oven I expect ?
Fixes: 131
It's not that old but I would guess the bulb wouldn't be covered in a warranty.
No..the cover's coming off as I can probably buy a genuine Panasonic part if needs be.
Fixes: 247
now what would your daughter say? Roll eyes
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
VileReynard
Seasoned Pro
Fixes: 11
Why not buy a torch, so you can check that your meal is rotating?
I had the same problem with my Sharp microwave - £30 microwave and needs an £80 engineer callout.
Took the outer cover off anyway and found it's a somewhat non-standard bulb, with a small metal bracket built-in for a screw fixing (and blade connections, though that's quite common).
In the end I had to buy a "similar" bulb online and do a tiny bit of O-level sheet metalwork to get it in place.  Lips are sealed
Fixes: 247
or switch the kitchen light on?
think of it as an greener way to cook  Tongue
Fixes: 131
Thanks guys and gals for all your useful suggestions so far. I shall take them all on board (preferably on an open top submarine (HPsauce excepted)) and see what transpires.  Roll eyesSmiley
Lurker
We keep it even simpler - we don't have a microwave. Smiley
pierre_pierre
just had a look at my Panasonic, it has a plate with two screws on the inside to the rear of the bulb
jnwright
It could be one of the lamps here.
Fixes: 131
@jnwright thanks yeah that came up high on my Google list. Just need to lift the lid and identify it.
@Pierre That's what I was expecting but was disappointed.
Fixes: 19
Hi Strat,
If you can`t see how to get at the bulb....... try this.....
http://toolmonger.com/2007/04/21/dealmonger-a-mini-nibbler-for-20/ ;     Wink
Fixes: 131
That's a good idea Shutter but I would then need one of these
which I am fully qualified to use.
Fixes: 19
Just order "on-line" .................. job done !     Cheesy
Alternative, use gaffa tape to stick the bit back in , and then you won`t need the welder !  Roll eyes
will be easier to change the bulb next time too !  Grin Grin Grin
