Metal Coat Hangers
gleneagles
Fixes: 16
Metal Coat Hangers
Well ok wood coat or anything else that you can think of that you have used for the purpose it was not originally designed for ?
often used the metal coat hangers to make hooks to hang tools on in the garage
Plastic storage boxes to make a cold frame for plants
Further ideas welcome
We are born into history and history is born into us.
19 REPLIES 19
2u2me
Re: Metal Coat Hangers
Found they are very useful when straitened out and you bend a hook on the end for fishing wires, and poking them through cavity's to pull cables through the wall Smiley
Pete11
Seasoned Pro
Fixes: 4
I found them good for the following....
Retrieving things from drains,
Radio aerials
Clearing out sink plug-holes
Back scratchers....
and a new use for them...hanging up clothes in the wardrobe. Cool_smiley
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
Fixes: 73
@Pete11 - I never knew you could use them for your last option - that is amazing.Grin
Pete11
Seasoned Pro
Fixes: 4
That's why I call my wife Google...she knows everything. She even has one with a magnet stuck on the end with a  bit of blue-tac for picking up needles, drawing pins etc.
billnotben
Making strong hooks to hang things on while you're up a ladder.
30FTTC06
Fixes: 4
Hook to pull the paddle out of the bread..
twocvbloke
They make terrible toothpicks...
30FTTC06
Fixes: 4
Depends how far down your gums have gone!
Mav
Fixes: 431
I seem to remember using some to make an advent crown in the 70's. Some sticky-backed plastic may have been involved, too Wink
Forum Moderator and Customer
7up
Fixes: 14
I remember in the 80s people used metal hangers as car radio aerials lol. If you had an intact telescopic aerial that some little **** somewhere hadn't damaged you were doing well.
Paper clips - jumper wires on PCB verroboard (don't work terribly well but they do kinda work) to replace a lack of tinned copper wire
Cable ties for key rings..
Bench drill as a rudimentary milling machine (didn't work great but i tried lol)
Car engine and chain as a garage door stopper (It's a big 2.5 with autobox sat on a trolley with the brakes on chained to the inside of the door)
Washer as a replacement lever in a lock
Plastic tube from an electric desoldering iron as a release tool for the car seat fittings so i could get the carpet up..
To name a few..
Strat
Fixes: 506
Wire coat hangers used to be great for unlocking car doors before the advent of double locking.
When in London I locked my keys in my car.
Police failed to gain entry but the wife's uncle got the door unlocked in 15 seconds with a coat hanger.
Customer and Forum Moderator. Windows 10 Firefox 88.0.1 (64-bit)
Alex
Fixes: 12
Yep @Strat now your history is coming out.
The old likely story of locking your own keys in. Tongue
Strat
Fixes: 506
I did wonder about the wife's uncle.
journeys
Plastic Milk and Juice bottles, cut the base out and use as a mini clotch to cover lettuce and brassica (cabbage, broccoli, Cauliflower)  plants, for a few weeks in spring until established
Helps survive frost, deterrent against slug, diamond back moths and other species of pests.
