Memory card
Memory card
Need an SDHC  card?
Need a 16Gb card?
Rush at the speed of light to your local Staples, who have 16Gb ScanDisk SD cards for £4.99
No I didn't believe it either and thought it was mis-labelled PoS, but expecting to pay more took it to the cash point to find that price is indeed right
NorthEasterner
Re: Memory card
I NEED NEED NEED!!!!!
Thanks for heads up!!
Edit - I need a micro SD card not SDHC  Sad
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Re: Memory card
It is the micro card.
Fixes: 45
Re: Memory card
Anything above 2Gb capacity will be SDHC whether it's micro or normal format.
Re: Memory card
Quote from: Petlew
... Staples, who have 16Gb ScanDisk SD cards for £4.99 ...
Speed of card?
Now Zen, but a +Net residue.
Fixes: 142
Re: Memory card
When with me on the plane pretty damn fast Cheesy
I could  not find it on their website so would also appreciate which class, please.
Forum Moderator and Customer
Re: Memory card
Hmmm!!  I'm only guessing, but this may be an in-store stock clearance offer, hence why you can't find it online Mav.
Having dug the pack out of the rubbish bin for you, it is marked "HD Video" on the front, on the back the store have usefully stuck their store security sticker over any useful info, there is however a number 10 visible in a circle, which I take to mean class 10.
And its SanDisk not ScanDisc.
It works very well in my in-car acc-cam.
