Main Road Traffic Reports
pierre_pierre
The Highways agency have been installing average speed sensors on a lot of roads that are linked into reporting systems. for instance my Sat Nav has a radio link via Classic FM that reports delays ahead on selected roads.
The info is also available on Google maps
and Frixo  http://www.frixo.com/ that also reports the average speeds near you - frightening sometimes, upgraded every 3 mins
The diagram below shows live average speeds on the A12.
M25  61mph
M25  73mph
A1023  68mph
A1023  73mph
A414  54mph
A414  73mph
A130  72mph
A130  73mph
A414  52mph
A414  73mph
A130  38mph
A130  76mph
A120  51mph
A120  74mph
A1124  55mph
A1124  74mph
A133  53mph
A120  56mph
A120  68mph
A120  65mph
A1117  38mph
A1243  38mph
Re: Main Road Traffic Reports
Interesting technology pierre but, I'm not sure what use it is for the average driver, unless it is identifying individual registration numbers!! (it might not now, but may well do in the future I suppose)
My SatNav uses the same delays reporting system as yours, how does this tie in with average speed info?
pierre_pierre
I think that the cameras do in fact look at the car registration and work out the speed between cameras as do these they do not book you for speeding, But I have a suspicion that the police link the info into the PNCS to check for illegal vehicles, near here in Essex the cameras are in small tubes about 100mm dia by 500mm on a pole
the Frixo site says the info is available on Mobile phone wep , take a look round it has a lot more than average speeds
Lurker
They record a portion of your number plate to enable them to track you between gantries, but its nothing to do with speed or any other type of traffic enforcement.
They are owned and operated by Trafficmaster.
pierre_pierre
the original ones were indeed traffic master and are usually green, but other seem to be on the increase, the multi ones on the gantry are the London Congestion Zone ones, also to check Commercials in the Pollution Zone
Uhmm! I rather thought this was a system linked into Highways Agency to warn of traffic congestion, a bit like the variable system used around Heathrow on the M25.
Although if it does indeed read registrations then there are obvious connotations of Big Brother watching. However, I thought that Police speed measuring devices were marked or warned as "Police" cameras.
pierre_pierre
the highways traffic cams are growing, this is just the M25 near the M11, not all are viewable  http://www.bbc.co.uk/essex/travel/jamcams/
I have to say, I've no objection whatever if cameras are being used by any third party to deal with traffic congestion, especially if it works! however in my experience traffic congestion for most reasons on motorways simply brings traffic to a stop, using the M25 variable linked speed limit sign system wouldn't do much good as there aren't enough escape routes between junctions, and anyway a diversion off a motorway usually only clogs up the minor roads nearby. If congestion is caused by an accident (and it often is) it is about time the Police dealt with the aftermath, particularly their addiction to measurement and assessment, much quicker than they do presently. Exactly why does an overturned truck on an off-slip road should keep a motorway closed for most of a day? If specialised lifting equipment will be needed, that will take most of the day to arrive at the scene, does the motorway have to remain closed? if so why?
Oh sorry, ref: last post,  I didn't realise there was another post covering this very issue, just looked at it, please direct any further comments of this nature to that post.
