Low usage
- General Chat
- Low usage
Low usage
Low usage
01-10-2013 8:15 AM
We are looking to gift an internet connection to a relative for Christmas. They are new to the Internet, and have an older Apple laptop. There are two main options:
1) a Mifi device from Three, offering 12GB over 12 months on a PAYG basis.
2) a monthly contract from Plusnet or TalkTalk
The Mifi, although less offering significantly less data allowance, is the least disruptive, since all of the good deals on broadband require moving the phone over from BT.
Can you really get by on effectively 1GB/month?
Re: Low usage
Re: Low usage
01-10-2013 8:31 AM
Re: Low usage
Re: Low usage
01-10-2013 9:33 AM
Quote from: CX Can you really get by on effectively 1GB/month?
Yes you can. Using the internet for email and basic surfing - train times, theatre bookings, weather, family history - burns up to a gig a month ( if you have teenagers on your home netwrok you'll know that 10 gig a week is not enough ). IMHO for low web usage, the pay as you go 12 or 3 month SIMs from Three represtent the best value for money, versus flexibility.
For a MiFi device, I recommend the factory unlocked TP-Link M5350, as it can be used on any network and internationally - like Spain. However, it needs charging so, if your user is always using the same fixed point, get a USB modem stick instead.
My tip for shaving data usage is to install an ad-blocking plugin on the user browser and disable all of that Adobe Flash bloat. And then set updates to 'inform me but do not download them'.
Re: Low usage
Re: Low usage
01-10-2013 9:37 AM
Re: Low usage
Re: Low usage
01-10-2013 11:06 AM
Now clearly if I got into gaming, downloading huge files, streaming video, that would be different. Infact when I listened to the streaming radio I expected to find I'd used more than normal and in reality I think I used something like 40-50MB more that day than I normally would (no idea how as i had it playing for hours lol).
If it's only internet surfing and not gaming, videos etc, 1GB is plenty. Even avast coped with it when doing auto updates.
If you were going to consider a plusnet connection / contract, why not get mifi on contract instead? - You'll get more bandwidth for it. I almost did this a few years about (then work went south) but they offered 15GB a month on 3 for a contract of £15 per month (I think) whereas I was spending £15 on PAYG for 3GB (which as stated above was utterly wasted lol)
Re: Low usage
Re: Low usage
01-10-2013 11:19 AM
Go for the 3g option IF it works in the house, check first.
Re: Low usage
Re: Low usage
01-10-2013 12:28 PM
As a minimum you should look at 2GB/month, but I think PN's 10GB package is perfect for low usage.
Re: Low usage
Re: Low usage
01-10-2013 12:51 PM
I suppose the thing that puts us off Plusnet is the requirement to take out their phone service too, and loss of trust with respect to pricing. £8.49 for a basic broadband-only service with a 10GB/month cap, and charging a further £25 activation fee, when the same can be offered for £5.99 when taking out the phone too. How do Plusnet justify charging broadband-only customers more? It isn't LLU when taking out phone too is it?
Re: Low usage
Re: Low usage
01-10-2013 2:14 PM
Quote from: CX How do Plusnet justify charging broadband-only customers more?
That's a good question CX. One only Bob Pullen can answer?? As for price rises, I suspect they will rise again with twelve months.
With respect to PAYG sim contracts, they are ideal for people who don't need broadband. Not everyone is a power user with 24-7 BT sport and Twittering. Maybe start your relative on a 3GB/90 day SIM and see how data they really eat?
A MiFi device is transportable too, so they won't pay those rip-off hotel wifi rates. However, MiFi devices need recharging. For daily use, best to get a 3G USB stick which plugs into the computer.
If you're feeling adventurous, you can use the 3G USB stick to build your relative a hybrid 3G wifi enabled network using something like the 'Zoom 3G/4G Wireless-N Desktop Router'.
Re: Low usage
Re: Low usage
01-10-2013 3:45 PM
Does anyone have experience of the bog-standard Huawei E5331/E5332 and whether or not it works whilst plugged into charge?
I already have a 3G USB stick, currently unused, but the age of the Apple laptop is going to be an issue with anything connected directly. It runs OS X 10.3.something, PowerPC G3 processor and only 384MB RAM, and virtually nothing offers support for 10.3 now whereas wi-fi is easy.
Re: Low usage
Re: Low usage
01-10-2013 5:46 PM
Quote from: CX Does anyone have experience of the bog-standard Huawei E5331/E5332 and whether or not it works whilst plugged into charge?
I just asked someone whose owns a 5331 and they said it works with the charger plugged in but, they're not sure if it charges. Go figure.
Using WiFi is the way ahead. I loath installing modem software, especially Vodafone's incarnations/incinerations of mobile connect. Anyway, a wifi hotspot gives similcast connections for laptops and Kindles, etc.
As said before, you can use the dongle to create a wireless hotspot by plugging the 3G USB stick into a 3G wireless desktop router. It's a bit more complex to set up but, the user support will be much easier - in theory. And being 'always on', a lot more stable.
To illustate, this 3G wireless router from TP-Link ( available in the UK ) can be used to do that
http://www.tp-link.com/en/products/details/?model=TL-MR3220
