Looks like one plane doesn't wan't to retire
Fixes: 170
Now we're REALLY taking off! Unbelievable video shows strong winds lifting a parked jumbo jet into t...
It looks kinda spookie, don't you think Huh
Forum Moderator and Customer
Re: Looks like one plane doesn't wan't to retire
This may explain it::
This is an old 747 freighter in a scrapyard. It has been stripped of all equipment and engines. The removal of the engines has the effect of moving the Centre of Gravity rearwards. Freighters tend to be tail heavy anyway, which is why you often see a tail strut fitted while they are being loaded. This aircraft did not get airborne. The main wheels are on the ground at all times. The aircraft was probably parked with the tailplane in the 'nose up' position which caused the nose to lift in the strong wind. All you need is for the CofG to be close to the body gear (the rear pair of the four wheel bogies) and the nose is liable to lift.
Read more: http://www.dailymail.co.uk/news/article-2150253/Unbelievable-video-shows-strong-winds-lift-parked-ju...
Fixes: 10
Certainly does look a bit eerie. A couple of times it sways left and right a bit and one time I thought it was going to tip over onto its wing!
Disappointed it didn't loft off the ground though lol.
