Logon
Logon
Prior to login, I seem to have two of my usernames at the upper right of the screen, when only one would I suggest be sufficient, both show the same thing when clicked.
2 REPLIES 2
Fixes: 80
Re: Logon
I think this is because your avatar can't be found (possibly linking to an image on the old community?) so the alt tag is showing in the absence of the image. Try uploading a new image or setting the default to resolve this.
Re: Logon
I posted about the avatar issue in the feedback forum, it's a certificate issue on the server where most seem hosted.
