Light-bulb labelling.
I suppose everyone now knows about the demise of certain light bulbs, but one snippet I wasn't aware of is that from 1st. September, the Eco-design Directive for Energy-using Products (EuP) means that lighting must labelled in terms of lumens, instead of electrical watts. The old 100w bulb had an output of around 1300 lumen...  useful chart shown below.
alanf
Re: Light-bulb labelling.
That's a surprise. LED less efficient than compact fluorescent? I thought LED was going to replace CFL when the price and colour balance was right.
I think the problem with LEDs at the current stage of evolution is the control gear in the base of the bulb, which isn't as clever as it could be. Give it another 18 months and it will probably change. Compact fluorescents were a bit like this when they first appeared (in jam-jar format).
I discovered a neat design of compact fluorescent recently called GX53.
It's a sort of flat disc, designed for example for downlighting in fitted firniture, but can be used in many places.
I think they go up to about 13W (as bright as an old 60W bulb)
magnetism2772
why?
when the unit of light is the candela
Nope.
Lumens is the "amount" of light emitted, candela is the intensity per unit area falling on a surface (roughly).
magnetism2772
a lumen is defined as one candela multiplied by one steradian
magnetism2772
oh  yes
and  light is radiated
magnetism2772
for the most technical
A candela is a measurement of the intensity of light- ie how much light
A lumen is a unit of standard measurement used to describe how much light
is contained in a certain area
pierre_pierre
well i never
Come on Pierre, you MUST have!!!!    Cool
magnetism2772
the differential equation is saying
a  lumen is the ratio of a small change in a magnetic flux  to a corresponding small change in time
thus the lumen unit is looking at  illumination in more modern terms to include  power (which is the watt per sec)
magnetism2772
the candela appears  just as a pure unit of  luminous flow ( to something)
pierre_pierre
why dont you learn to use joined up writing threads
magnetism2772
thanks for your contribution peirre
Do you think what i've said is correct ?
