Lengthy Backup
Fixes: 131
Lengthy Backup
As far as I am aware all I am backing up is my 'C' drive not the entire internet. Undecided
I don't think my PC will last 136 years.....I know I won't Sad
Customer and Forum Moderator.
Fixes: 62
Re: Lengthy Backup
That usually happens when there is a problem with the drive.
I had to do a scandisk with the full fix options and a reboot to sort it
Fixes: 131
Re: Lengthy Backup
It shows that when I maximise it from the system tray.
After about 15 seconds it refreshes to show around 3 hours.
Currently transferring to the NAS drive at around 60Mbs.
VileReynard
Seasoned Pro
Fixes: 11
Re: Lengthy Backup
The routers that Plusnet hand out can only transmit at 10Mbps per wired port.
You will be very lucky to achieve rates of 500KBytes/sec unless the data is highly compressed.
Fixes: 131
Re: Lengthy Backup
Gigabit ports on Billion 7800n as per my sig Wink
pwatson
Re: Lengthy Backup
Quote from: vilefoxdemonofdoom
Care to revise that and put the zero back that's missing? Smiley
VileReynard
Seasoned Pro
Fixes: 11
Re: Lengthy Backup
Oops - sorry  - that should be 100Mbps - so you might get 5MBytes per second over your network.
Still sluggish though.
Can I have a gigabit router please?
Fixes: 131
Re: Lengthy Backup
@Jeremy I refer my learned colleague to this http://community.plus.net/forum/index.php/topic,116636.msg1007925.html#msg1007925
Fixes: 247
Re: Lengthy Backup
sure, buy one like the rest of us Wink
i've recently purchased an Airport Extreme which has gigabit ports..
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
VileReynard
Seasoned Pro
Fixes: 11
Re: Lengthy Backup
Amazon are selling a Billion for £120!!!
But it has an extra ADSL connection which wouldn't get used.
Perhaps I should get a cheap 5 port Gigabit switch feeding my 100Mbit router (for internet/firewall/NAT/DHCP/wireless) purposes?
(cost - less than £15)
Clearly the cost of a fast port isn't in the hardware.
Fixes: 19
Re: Lengthy Backup
Quote from: Strat
Dads Book....... would that be "war and peace".... ? ? ?  Cheesy
Fixes: 131
Re: Lengthy Backup
The Life and Loves of Strat.....it's a leaflet Sad
Re: Lengthy Backup
I backed up the whole of the internet once .........
Fixes: 19
Re: Lengthy Backup
Quote from: Strat
As I said.......... "War and Peace"    Cheesy
Fixes: 10
Re: Lengthy Backup
Quote from: picbits
Lol.. love the error/success message  Cheesy
