Laptop
Laptop
A work colleague is upgrading his laptop from a three year old Toshiba and selling it off, I have been considering it for the sole purpose of flirting with Linux.
Knowing nothing about Linux, can the s/h Toshiba's HD be re-formatted and a clean install of Linux be installed, if I download the Linux to CD/DVD on this PC?
1 REPLY
Fixes: 10
Re: Laptop
AS long as you can get it onto the laptop yes.
If the laptop has a CD/DVD drive and you can burn the CD/DVD on your current machine then no problem.
If the machine does not have a optical drive, you'll need a USB drive.
