Laptop used as a desktop - not really a hardware support question
Fixes: 62
This is something I have just thought about
At some point I will need to replace my better half's XP computer
When I used laptops at work - in the dim and distant past  Grin - I used to plug in an external monitor, keyboard and mouse. The latter two would presumably be via usb ports
Is this still an option with a sensible priced laptop or am I wasting my breath looking for one
Re: Laptop used as a desktop - not really a hardware support question
A quick search for a cheap-ish laptop shows both VGA and HDMI interfaces on this one: http://www.dabs.com/products/lenovo-refurb-g505-e1-2100-4gb-1tb-15-6--windows-8-1-9XQ8.html?src=3
HDMI here: http://www.dabs.com/products/hp-stream-11-pro-intel-celeron-n2840-2gb-32gb-11-6--windows-8-1-with-bi...
(and that's just the first two I looked at).  Smiley
Call me 'w23'
Fixes: 162
Shouldn't be an issue on the majority of laptops Jim, I do that at work and home on laptops of differing ages and specs.
 Chris Parr
 Plusnet Staff
Fixes: 62
Thank you all - this topic can now go to sleep
Previously I built my own computer but given the retail cost for an i5 or similar CPU plus buying Win 10 there doesn't seem to be any point
Quote from: Oldjim
I'm running a couple of (desktop) machines built with recent Pentium 'G' processors, unless you need serious gaming power these work very nicely for well under £50.
Laptop processors can be comparatively weak.
Call me 'w23'
Fixes: 62
Since I would be looking at a 10 year life I would be going with a quad core CPU and the i5 is the best bet for that
Beware, current i5 mobile processors are 2 core: http://ark.intel.com/products/family/84980/5th-Generation-Intel-Core-i5-Processors#@Mobile
For cheap quad core look here (MoBo with soldered-on 4-core Pentium): http://www.amazon.co.uk/gp/product/B00MY825V8?ie=UTF8&tag=pric097-21&linkCode=xm2&camp=1634&creative...; Wink
Call me 'w23'
Fixes: 62
nasty - looks like a microATX case is the way to go
I managed to bag one of these for a tenner on ebay last year: http://www.lian-li.com/en/dt_portfolio/pc-q03/ (one of my Pentiums sits on an mini-itx board)  Smiley Smiley
Call me 'w23'
Fixes: 6
Only thing to be aware of is how you want to connect the monitor (VGA, DVI or HDMI, etc.).
Cheaper laptops can lack HDMI, but of course that's only a problem if you need it.
An IT person made the mistake here - purchased a meeting room laptop assuming it had HDMI and it didn't. So we have to use VGA on it.
that's the setup i'm using at present, oldjim, while i wait on the arrival of a new box.  getting the resolution right is a bit of a faff and i lose a bit at the bottom of the screen.
when using the external monitor the laptop monitor is virtually unusable and i also had to put the panel (taskbar) at the top of the screen.  i don't know how one does that in windows.
i also use a laptop cooler and turn off the laptop and monitor when i go to bed.
from my perspective it's a temporary measure, but it seems that laptops are much more robust these days.
good luck with it.
Fixes: 12
Quote from: Alex
or just use a VGA (or DVI) to HDMI converter.
and half-assed IT person would have worked that one out quickly enough.
Fixes: 6
It only had a VGA output - the meeting room screen had a VGA input too so he just used that.
@oldjim...    I can thoroughly recommend PCSpecialist as being almost build-it-yourself with a guarantee to boot. I've had six laptops & PCs from them without any problems whatsoever, and they are definitely cheaper than the branded items.
http://www.pcspecialist.co.uk/index.php
