Knock! knock!
Knock! knock!
Petlew quietly edges the door open a little, peeps in to see if there's anybody at home...
Fixes: 153
Re: Knock! knock!
There's nobody here but us chickens....
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
198kHz
Seasoned Pro
Fixes: 9
Re: Knock! knock!
Papyrus and Comic Sans walk into a bar. The bartender says, "Get out -- we don't serve your type."
Re: Knock! knock!
That's a very corny old joke Foresee!
Fixes: 153
Re: Knock! knock!
I thought it was particularly fowl too...
Re: Knock! knock!
We should at least try to get the pecking order right...
Re: Knock! knock!
My dog must think he's a blacksmith cos every time I kick his backside he makes a bolt for the door!  Oi !!!
Fixes: 153
Re: Knock! knock!
Quote from: Petlew
sure there will be someone to take you under their wing...
Lurker
Re: Knock! knock!
Quote from: adiewoo
A bird of a feather if you will...
Re: Knock! knock!
Now, we really are scratching around now!!
198kHz
Seasoned Pro
Fixes: 9
Re: Knock! knock!
Can this be the end of the run? I'll chick back later.
Re: Knock! knock!
Don't egg him on Wink  It's no yoke Smiley
scootie
Re: Knock! knock!
egg tastic is this thread, lets hope it can take off and that the fox dont get to the thread first
Fixes: 153
Re: Knock! knock!
there are some truly egg-cruciating puns to be had I feel Sad
SRD
Re: Knock! knock!
In the meanwhile the fowl politicians are feathering their nests.
