Kevin Spacey
Kevin Spacey
Kevin Spacey was on stage performing at The Old Vic when a phone rang in the audience. Not phased at all and remaining in character Spacey said 'If you don't answer that, I will'.  One very embarrassed audience member I bet.
Kevin Spacey
I would have loved to have been there Wink
Fixes: 247
Re: Kevin Spacey
such a fine actor.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
TORPC
Re: Kevin Spacey
It's like Roy Chubby Brown
He used to say to a member of the audience after they stood up
"I know where your going" & then take the mick out of them Tongue
Re: Kevin Spacey
Quote from: dvorak
such a fine actor.
Yes I agree. It's a pity he's leaving the Old Vic after 10 years. He has done so much there.
