Just a quicky
Just a quicky
I expect this should be posted elsewhere but, does anybody remember the dial code that reveals the phone number on a mobile phone?
I've just put a new PAYG SIM in an old mobile phone, and can't remember the number, so at the moment I can't put any credit on it.
Ta!
Re: Just a quicky
Can you ring your land line number? If so, just ring your land line number (but don't answer it) then dial 1471 on the landline.
Fixes: 10
Re: Just a quicky
New SIM - isn't the number tied to the SIM not the phone?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Steve
Seasoned Pro
Re: Just a quicky
You can also try looking in the phone settings and look for phone settings and see if you can find your number that way, Would help if you tell us what network and what make of mobile it is? If its vodafone just dial *#100# and your number will appear on screen
Edit.. Look for something like handset information and it should tell you the mobile number.
If life gives you lemons, make lemonade.
Re: Just a quicky
Ah! thank you, that's the one.
Thread ends.
Re: Just a quicky
When I read the thread title I did not expect to read about phone numbers Tongue
Steve
Seasoned Pro
Re: Just a quicky
Why Santiago? Would you like one? A telephone number that is( sorry  Embarrassed  )
Re: Just a quicky
I have more telephone numbers than you could shake a stick at.
However when I read "Just  a Quicky" I was expecting a tale of intimate brevity. Roll eyes
Fixes: 224
Re: Just a quicky
[me=adiewoo]gives Santiago a hug.[/me]
That quick enough for you?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Re: Just a quicky
Three minutes.....    Yup that would be it. Thank you Hun
Re: Just a quicky
Quote from: Santiago
Petlew, overcome with indignation...I'm sure I don't know what you mean!!!!!
pierre_pierre
Re: Just a quicky
are you that old  Cool Cool
Fixes: 10
Re: Just a quicky
Because of a couple of other threads I misread the title of this topic - I thought it was Just a quacky
Fixes: 224
Re: Just a quicky
[me=adiewoo]sends Jelv to the funny farm to be assessed by the quacks.[/me]
Re: Just a quicky
Quote from: pierre_pierre
are you that old
No, but any other interpretation may contravene forum rules.
