June 6th Will you miss it ?
Fixes: 9
What happened in 1761 that will occur on June 6th this year and if you miss it will not be around again until December 2117. ?
Lets see who is quickest to answer that question.
randpwar
Re: June 6th Will you miss it ?
I can't beleive the last time we had a daft question in chit chat was 1761 and I'm sure we'll have another one before 2117  Wink
randpwar
198kHz
All Star
Fixes: 10
Transit of Venus - and it'll be cloudy!
Remember you are unique - just like everyone else
SWMBO is currently working on a biography of James
Fixes: 9
Credit where it's due you guys are on the ball !!
198kHz
All Star
Fixes: 10
Must be all the intra-venus injections.  Crazy
Infinity
Seasoned Pro
Quote from: gleneagles
The Queens' Jubilee !
Fixes: 100
..... that will occur on June 6th this year and if you miss it will not be around again until December 2117. ?
Plusnet's Product Refresh
/Coat
Customer and Forum Moderator.
Infinity
Seasoned Pro
No changes in the short term.
Quote from: 4C
Transit of Venus
Does Venus drive a long wheel base diesel van?
3Mb FTTC
World IPv6 Launch day?
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Fixes: 9
Quote from: randpwar
http://www.guardian.co.uk/science/2012/may/13/starwatch-venus-transit-sun-planets
What do I win!! Cheesy Cheesy
Well you are on the road to a major prize all you have to do is answer a second question correctly and the prize is yours subject to the following conditions,
1. You PM me the answer before midnight Friday 18th May 2012
2. You do not display the answer on the forum
3. you don't disclose the answer to anyone else
You are allowed to do any research or consult with anyone who might be able to help you with the answer and you can have 6 attempts to get it correct but it must be fully correct.
If you get it right then it will be the biggest prize you are likely to have ever won !
Now on to the question,
What are the 6 winning lottery numbers for this Saturdays Draw ?
NB: They do not have to be in the order drawn (just to make it easier for you) but they must all be correct !!
@gleneagles:- .............If I PM'd you six numbers could you take the risk and afford not to do them? Roll eyes
Fixes: 9
Ah, but that's why I was replying to randpwar rather than anyone else on the forum.
The prize is not specified other than it's a major one, now if randpwar does send me a list of numbers he will have to do the same numbers himself (assuming he gambles) or he could take the risk of not doing them and end up in a position where he has won the lottery for me (the ticket holder) and he ends up with what I consider a major prize !!
Stranger things have happened !
