James' Pool Balls
Fixes: 103
James' Pool Balls
(Please no puns in this thread)
James, I've just this second noticed that the pool balls in your avatar aren't actually set up correctly. What's all that about!? Wink
Re: James' Pool Balls
no puns?  spoilsport.  Tongue  Cry
A'hem, perhaps for the benefit of those of us who don't know, you would tell us how the balls should be set up....cue Bob;
Bob_Milton
From Wikipedia,
One of many correct nine ball racks: the 1 ball at the apex centered over the foot spot, the 9 ball at center, the other balls placed randomly, and all balls touching
Bob_Milton
And also from Wikipedia, just to make it clear?
A proper straight pool rack with the 1 and 5 balls as the two corner balls and all other balls placed randomly
Intragame racking
Because straight pool is played to a specific number of points normally far in excess of the 15 points available in the initial rack, multiple intragame racks are necessary. Intragame racking employs a separate set of rules from those in place at the game's start.
To reach the point where an intragame rack becomes necessary, the balls are played until only the cue ball and one object ball remain on the table's surface. At that time, if neither the cue ball or the fifteenth object ball remains in the rack area (or is interfering with racking in the rack area) the fourteen pocketed object balls are racked with no apex ball, and the rack is placed so that if the apex ball were in the rack, its center would rest directly over the table's foot spot. Play then continues with the cue ball shot from where it rested and the fifteenth, non-racked, object ball from where it rested prior to racking
Fixes: 103
Quote from: petlew
I was thinking along the lines of either of the following...
I have always played pool, in many pool halls in the UK, EU and US, where the balls were as shown in the first image rack.jpg.
SW.
3Mb FTTC
James
9 ball is different Bob.  You only need the 1 at the front with the 9 in the middle, no other arrangement matters.
With US 8-ball, I beleive it's similar (I don't play US) with only a few ball arrangements being required.
UK 8 and World 8 are different though with their set arrangements of balls.
Bob_Milton
See reply no.3
Fixes: 179
Racking up a Snooker table is a lot easier...just the brown, green and yellow to get right Undecided.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
James
GBY - God bless You.
Easy to remember Smiley
James
Yes Bob, we weren't talking about 9-ball hence my post giving clarification.
Bob_Milton
Whatever,
It is supposed to be King George 5th who put a comment on a report he had read, it said 'round objects', apparently the civil servants wanted to know who Round was who objected.
