Issues with BT Speed Test Site
Mook
Champion
As this isn't specific to Plusnet so I thought it best to put it here, it is after all a general question.
Which is: Does this happen to anyone else?
When I use the BT speed test site I always get stupid results like this!
Then when I try the "Additional Diagnostic" I get this:
after I've entered and confirmed my phone number, it remains on screen and never changes.
This has been ongoing for some time so does anyone have thoughts on this?
8 REPLIES 8
Strat
Fixes: 505
Re: Issues with BT Speed Test Site
I had reason to use it recently and the first stage gave reasonable results but the 'additional diagnostic' failed to run and suggested I try later, which I did with success.
I used to get wacky speed results on the previous version.
Customer and Forum Moderator. Windows 10 Firefox 88.0.1 (64-bit)
Fixes: 5
Hi @Mook
This has been discussed previously here.
I've only seen this behaviour using an iPhone, Windows, Linux and Android all fine, wireless and wired.
Hope this helps
Dan
Mook
Champion
I knew that @Dan_the_Van having contributed but as a thread its stalled so I thought I'd try again. Well nothing ventured nothing gained.
archerry
@Mook
I got the normal report just now using our phone number.
Downloaded report attached.
Regards,
Alistair
Edit: Firefox on kubuntu 20.04
acr
I have the same problem when using Safari (on a Mac). A recent test is reporting my download speed as 205.98 Mbps ! Previous tests using Safari have all been similar. When trying "Additional Diagnostics" it always gets stuck at the same point as with you.
If I use Chrome (on the same Mac) it works correctly.
Mook
Champion
Interesting, so for what it's worth I'm using Safari v14.0.3 on OSX Big Sur v11.2.2 with a DrayTek 2952 Dual Wan Router. I'll fire up an Ubuntu VM see what that gives me.
Used a running Windows Server instead and when using Firefox on Windows and it worked so this would appear to be an issue with Safari. Would never install Chrome on anything @acr but thanks for letting me know it works.
Fixes: 73
Apart from the Upload - just not possible.
goldenfibre
Seasoned Pro
Fixes: 12
Mine seem fine after click Run Diagnostic as the test result came back within a few seconds.
