Is this worth buying?
Fixes: 20
I have an option on a new motherboard & processor (new to me that is)
Gigabyte GA-78LMT-S2P Motherboard with AMD FX4100 Processor
Any clues on how good/bad/indifferent this is?
As a comparison I am running a Dell 9200 with a Intel core2 6700 running at 2.66Ghz with an Nvidia GT610.
rongtw
Fixes: 12
Re: Is this worth buying?
Gigabyte are Good MB,s , the Fx 4100 is a solid CPU i have had one previously.
The thing to remember is what Ram you have ? is it the same for the new MB DDR3 , you may also have to check your PSU for same connections  Wink
nanotm
if you play any games or do photo/video editing then you will probably find the processor underpowered, however if you just do word processing /spread sheets stream films and browse t'internet then it will probably be fine,
I bought a similar combo last year for my youngest, except his is an A8 chip and I added in a separate graphics card because I needed the HDMI output it offered
Fixes: 20
It will need new ram and a new case (I have plenty of cases though) as the Dell is a BTX board. (Remember the "New" standard Intel brought out years ago with no ports apart from usb)
As to playing games, well I play Xcom and Civ V currently, so it should be faster with it. As to the other bits you suggest I do all that on this one anyway.
Got to see if it is worth the money at the moment as I will have to shell out £30+ for 4Gb of ram.
Must admit at the moment I think it will have to wait for next year before I upgrade this box.
Esp as this is the 10th! time in the past hour my router has rebooted itself, so a new router might be a better buy!
Fixes: 4
Fixes: 20
Way too expensive for me. I was looking @£50 for that bundle +the ram. But with the router playing silly bug**rs it looks like it will be getting replaced first.
Had some cash back from my house insurance just paid so had some spare cash, but not that much.
nanotm
if you have an extra couple of quid you could get this router and still get your upgrade Smiley http://www.ebuyer.com/516779-on-networks-wireless-n300-adsl-modem-router-n300rm-199uks
Fixes: 20
Nah I need a fibre router preferably a combined one. Currently using the TG589vn v3  which has been solid until this past few months, daily reboots were common, but last night it was just going silly between 6-7 when I gave up on it.
I changed the psu in case it was dying but it still rebooted several times after that.
Current stats:
2.1 Type VDSL
2.2 Status Up
2.3 Uptime 0 days 3 hours 3 mins 7 secs
So managed to stay up for past 3 hours  Shocked
Mind you someone trying to hack it:
Info Sep 23 10:48:17 LOGOUT session of user root killed (122.225.109.209)
Info Sep 23 10:48:12 LOGOUT session of user killed (122.225.109.209)
Info Sep 23 10:48:09 LOGOUT session of user root killed (122.225.109.209)
Info Sep 23 10:48:02 LOGOUT session of user admin killed (122.225.109.209)
Info Sep 23 10:47:50 LOGOUT session of user root killed (122.225.109.209)
Info Sep 23 10:47:47 LOGOUT session of user root killed (122.225.109.209)
Info Sep 23 10:47:38 LOGOUT session of user admin killed (122.225.109.209)
Info Sep 23 10:47:19 LOGOUT session of user root killed (122.225.109.209)
Info Sep 23 10:47:08 LOGOUT session of user root killed (122.225.109.209)
Info Sep 23 10:47:01 LOGOUT session of user root killed (122.225.109.209)
Info Sep 23 10:46:49 LOGOUT session of user root killed (122.225.109.209)
Info Sep 23 10:46:46 LOGOUT session of user admin killed (122.225.109.209)
Info Sep 23 10:46:40 LOGOUT session of user root killed (122.225.109.209)
Info Sep 23 10:46:19 LOGOUT session of user admin killed (122.225.109.209)
Info Sep 23 10:46:04 LOGOUT session of user root killed (122.225.109.209)
Info Sep 23 10:46:01 LOGOUT session of user admin killed (122.225.109.209)
Info Sep 23 10:45:52 LOGOUT session of user root killed (122.225.109.209)
Since remote admin is off they won't get in.
sjptd
If you are running Windows it may complain about a change to m'board and processor; especially if it was a Dell OEM version. That could end you with another big expense.  .
The old processor should do most things pretty well.
I have a 7 year old desktop with 6600 and am just in the process of moving over to a laptop with i7.
Smaller jumps aren't worth the effort in my mind; and there are only a few specialist tasks my old machine doesn't handle adequately.
You may do better to invest in an SSD which will improve your current machine a lot, and which you will be able to move into a new machine when you eventually upgrade.
Fixes: 20
Nah not running win not for many years.
Linux will run even with a complete change of video from NV to Amd just not with the dedicated driver  Grin
It will be next year before I am in anyway near getting a new setup, when my endowment comes up (mortgage paid years ago, kept the endowment running), then I will be able to get a new board but this look interesting at the mo as in interim update, might have been as much as 50+% faster but if I have to get a new router then it is back on the burner again.
My ping graph from yesterday:
So for 4 hours it was unusable.
nanotm
stupid question maybe but how long have you had your router and where did you get it from ?
I ask since they only started getting sold about 12 months ago on broadband buyer, so if that's when you got yours it would still be within the 2 year warranty period.
on an aside the broadbandbuyer site has them listed as only having 10/100 Ethernet ports that would make them a poor choice for wired equipment that transfers files across the network .....
Fixes: 20
I got it from here, a PN trial. I did enquire about a replacement but they said no more available. I have it connected to a Gib switch so no issues about speeds internally. And I only have 3 things with Gib nic's in them anyway.
Looking at the TP LINK TD-W9980 just now, £71 from Dabs at the mo, bit more than I have spare but necessity is the mother of invention as they say.
nanotm
if you like the one you've got you could just get a direct replacement
http://www.broadbandbuyer.co.uk/products/16234-thomson-tg589vn/#Content and its only a few quid more than that pc bundle but a deal cheaper than the tplink Smiley
Don't know if they'll sting you for delivery but...
http://www.overclockers.co.uk/showproduct.php?prodid=NW-127-TP&campaign=affiliate/tag
Call me 'w23'
Fixes: 20
Looked cheap until the p&p was on
Total : £74.58
