Is this an urban myth
If you should ever be forced by a robber to withdraw money from an ATM machine, you  can notify the police by entering your PIN # in reverse.
For example, if your  pin number is 1234, then you would put in 4321.
The ATM system recognizes  that your PIN number is backwards from the ATM card you placed in the  machine.
The machine will still give you the money you requested, but unknown  to the robber, the police will be immediately dispatched to the location.
All ATM’s carry this emergency sequencer by law
received it in an email.
pierre_pierre
Re: Is this an urban myth
Snopes can usually help you with these questions.  Wink www.snopes.com
(As can commonsense  Roll eyes )
http://www.snopes.com/business/bank/pinalert.asp
Great minds.........................  Cool
itsme
If it was true the robbers would soon rumble it as the card holder fumble to enter the PIN backwards..
Fixes: 10
If were true and my PIN was 7117...
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 225
Perhaps the PIN 4357 should be reserved for such cases... Wink
Forum Moderator and Customer
As an aside; at a trade show I was given a calculator sized bank PIN card reader like the ones many banks distribute to their customers to verify on-line banking. The difference with this reader is that it works with every banks' PIN debit/credit/prepay card. If it got in the wrong hands the device would be a mugger's delight enabling them to check on the spot the PINs against the credit cards "given" to them by their victims.
Now Zen, but a +Net residue.
Fixes: 20
How is that a difference? Chip and PIN card readers are interchangeable anyway!
itsme
Is the PIN encoded on the card? If it is then it's a very poor security system.
Quote from: HPsauce
Sometimes in short supply Roll eyes
@itsme, the PIN cannot be encoded on your card as it wouldn't work when you changed your PIN.
VileReynard
Seasoned Pro
Fixes: 11
Banks know nothing about security.
NatWest insist I enter 3 out of the 4 digits in my pin (plus some other stuff) to do internet banking.
Maybe you should change your bank Wink
Lloyds don't ask for your PIN for internet banking.
itsme
Do the banks know the card PIN? I would have thought only Visa MasterCard  would know it
VileReynard
Seasoned Pro
Fixes: 11
Depends whether you talking credit or debit cards.
itsme
Both. Debit cards go through the Visa system.
