Is there nothing you can't do with a mobile today?
Fixes: 225
Denmark to swap stamps for texts
Danes sending a text bearing the word "PORTO" to the 1900 number will get in return a code that must be written on a letter in the place they would usually stick a stamp.
Initially only letters up to 50g in weight can bear the mobile postal code. Getting a code will cost 8 DKK (£0.92p), the standard rate for a letter, plus the usual cost of a text message
"We will, of course, still keep the Danish stamp tradition alive as the stamp adds qualities to a letter," he said.
The cost of a stamp remains the same but you do still have to pay the standard rate for sending the text.
My nearest post office is over a mile away so, for the odd urgent stamp I suppose I could go for the convenience but I usually have a stock of 1st and 2nd class stamps anyway.
Forum Moderator and Customer
Re: Is there nothing you can't do with a mobile today?
Some of us even make phone calls using one...
Petlew retires to look up the definition of dinosaur...
James
di·no·saur   
[dahy-nuh-sawr]
–noun
1.
any chiefly terrestrial, herbivorous or carnivorous reptile of the extinct orders Saurischia and Ornithischia, from the Mesozoic Era, certain species of which are the largest known land animals.
2.
something that is unwieldy in size, anachronistically outmoded, or unable to adapt to change: The old steel mill was a dinosaur that cost the company millions to operate.
Origin:
Yup! sounds about right...
johpal
With my mobile connected to the internet (via home WLAN), I could print out electronically stamped mail, but the effort of doing so would not be worth the effort! I hope a similar solution as the Danish one, will arrive in the UK and soon. I don't have the time to get to a Post Office to buy stamps.
In Finland, it has been possible for some time to buy items from vending machines, using your mobile to make payments.
