Is facebook down for anyone else on plusnet?
racquel
All other sites fine, facebook down for 2 hours now.
Is it just us/plusnet/the world?
I can get to facebook front page via IP address
Fixes: 173
Re: Is facebook down for anyone else on plusnet?
Ok here.
Customer and Forum Moderator. Windows 10 Firefox 63.0.3 (64-bit)
racquel
Problem solved! I'm using Google Chrome for virtually everything now, and I'd restarted it and the computer and still Facebook was down.
I tried another browser - Facebook was fine. I then noticed than Chrome said "waiting for cache" all the time on Facebook.
I cleared the cache, et voila, Facebook worked perfectly! I think that's been the only weirdness I've ever had with Chrome, which isn't bad!
StickyMick
Facebook's a flippin kludge anyway. It's always chucking up errors, and when you contact support you just get a bog standard reply that says "Clear out your cookies and history."
