Internet Explorer help!
NorthEasterner
I went to my local tip to dump some stuff that we no longer needed.  Once I was their, I saw a innocent looking Dell PC that someone had left.  I've decided to bring it home and clean it all out.  It booted up all effortlessly (well a little slow) and reset the entire system to factory (for security reasons) and freshly reinstalled XP (home edition)  Now I'm stuck with the old horrible internet explorer when XP was released.  When I try to google Internet Explorer 8 (latest for XP) I get bounced out by Microsoft telling me I MUST upgrade my operating system or computer.
I am looking to download IE8 from a different source, but fear of downloading a virus.
Nice litle PC (Dell Dimension 5000)
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Fixes: 62
Re: Internet Explorer help!
That is probably as you haven't installed all the XP service packs
NorthEasterner
I'm on service pack 2 at the mo.
What's the latest, and where do I source them from?
Fixes: 62
You need SP3
Doesn't windows update do it if you run it manually
Otherwise this is a starting point http://windows.microsoft.com/en-GB/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
NorthEasterner
I'm automatically redirected to - http://windows.microsoft.com/en-gb/windows/upgrade-your-browser
Urrghh so frustrating!
Fixes: 62
nanotm
try here
http://www.microsoft.com/en-gb/download/internet-explorer.aspx
NorthEasterner
I've downloaded Google Chrome and use the link that @OJ provided - installing now.
I hope this service pack updates IE
