Interference PLT report BBC
G3YBO
If you find that your internet is slow, check for interference with a portable radio.......It maybe your house or next
door using Homeplug/PLT...........Can be a problem for up to a half mile.....
http://www.theregister.co.uk/2011/04/13/bbc_plt/
http://www.ban-plt.co.uk
Regards
Roger
Re: Interference PLT report BBC
Erm?  Nothing in the BBC report, or the reports of the report say anything about PLT devices slowing down your internet, and its only the faster PLT devices when under load that interfere with your radio.
From the Register "The BBC engineers did find that when the PLT equipment had trouble making a connection – if it were, for example, on a separate ring main or used in the presence of a compact fluorescent lamp – it would fall back to the HF band and thus only bother the hams and their ilk. But the engineers noted that when the kit was running at top speed it was able to knock out the DAB reception entirely at one of the houses tested."
G3YBO
Hi fourfourdeveon.............These units are so dirty and it has been proved they can cause interference with ADSL
Read through  www.ban-plt.co.uk and see tests.......
Regards
Roger
I remain to be convinced about ADSL interference, not saying its not possible, far from it, but the jury is out and a campaign group will jump any any inference that supports their view.
I've used homeplug devices extensively for many years and have experienced the radio interference discussed, but have never experienced ADSL problems despite a home plug being plugged into the same socket as the router.
G3YBO
Hi.............ADSL and ADSL2 both run up to 3Mhz, FTTC up to 4.3Mhz with plans to use up to 12Mhz, PLT runs 2 to 30Mhz and
up to 300Mhz on some units...........So in time I am sure it will all come out.....
Regards
Roger
geoffp0
Has anyone ever used these units and do they work? I see there are some for sale on ebay Cheesy
Quote from: fourfourdevon
I've used homeplug devices extensively for many years...
johpal
I have used homeplugs for a year now, connecting my internet tv and blu ray player to the home network, as an adjunct to the wireless network. Never experienced any problems with speed, or radio (analogue or digital) interference.
Fixes: 13
Quote from: johpal
But your neighbours might have.....  Cry
Fixes: 9
At one time a number of televisions suffered from interference from CB/Amateur Radio Transmissions, this was more down to the tv lacking suitable filtering than anything else and could often be sorted by winding the ariel cable a few time around a ferrite ring.
Not sure if the problem still occurs in today's TVs
No doubt with the ever increasing demand for frequency space more interference problems are bound to happen.
johpal
@shutter
We are on very good terms with all our immediate neighbours, both with and without w-ifi networks. As I stated, no problems. Is it possible, the interference could skip a couple of hundred yards in all directions and cause my neighbour on the next street misery? Possibly, but I doubt it.  Tongue
Epyon
I'm planning on buying 200mbps homeplugs
anyone suggest a good set?
I've always found Homeplugs to be pretty much of a muchness.
However, I've also found the 200mbps devices to be absolutely no faster than the 85mbps devices.
David_W
I'm using a homeplug now, well, two of them.  One is plugged in by the BT master socket where my router is and I'm connected at a solid 8128 even though I'm at the very limit so really shouldn't be getting these speeds (31db d/s - 2 db above where I should be for 8128 with fastpath off) so the homeplug isn't affecting my DSL connection at all.
