Integrated fluorescent ceiling light goes dark after about 20 seconds
daveplus
Fixes: 8
Hi
Does the above indicate that the unit needs to be replaced?
Dave
9 REPLIES 9
Steve
Seasoned Pro
Re: Integrated fluorescent ceiling light goes dark after about 20 seconds
Perhaps, check that all the fittings are secure.
If life gives you lemons, make lemonade.
shutter
Fixes: 47
If it doesn`t light up, when switched on..... or keeps "trying" but never quite makes it.... or maybe sometimes it does.... fault is usually the little starter cartridge
Going "dark"  after being switched on... sounds like the tube needs replacing.... ( a new starter for the new tube at same time would be good idea ) .
Alex
Fixes: 12
Yep I know nothing about DIY.
It could be the bulb is on the way out, or a dodgy starter. For what they cost I would replace both. Does the bulb switch on straight away, or does it take some time flickering beforehand? If so, then both may need replacing.
Can't see it being a wiring problem, otherwise it wouldn't work at all.
Minivanman
Aspiring Legend
@Alex
Can you post up a picture of the light fitting?
It might give us a better idea.
Don't limit the friends you haven't met with arguments you'll never have.
Fixes: 74
@Minivanman It's @daveplus asking the question.😉
daveplus
Fixes: 8
Thank you all.
I disconnected the power wires from the light and connected a  simple bulb socket to check the wiring and that worked fine. So the original is now in the bin.
Dave
Minivanman
Aspiring Legend
@jab1
D'oh !
shutter
Fixes: 47
@daveplus  If you had posted this in Tech Help.... you could have given yourself a
This fixed my problem
CheesyCheesyCheesy
Minivanman
Aspiring Legend
All this is way over my head.
