Inserting Image
Inserting Image
I have asked this before but forgotten how to do it.  Can someone please tell me how to insert a picture in a message?  I have clicked the 2nd button but nothing seems to work from there.
Re: Inserting Image
simply use the [img]http://tags if you want to hotlink to an image on the internet.
Use [img]http://addressofimagehere.com[/img]
Or, click additional options under the compostition box, and you'll find an option to upload .jpeg files directly to the site from your computer.
pierre_pierre
Re: Inserting Image
the first one puts it in the Body, the second at the end
Re: Inserting Image
Thanks James_G.  Just tried it out and I hope it shows in a new post.
Re: Inserting Image
Quote from: pierre_pierre
Thanks Pierre, I'll try the other way later.
