Improvements since moving to Plusnet
SoFarSoGood
Hi all
Since moving to Plusnet, I have noticed a marked improvement in the overall sound quality of streamed music.
The bass goes deeper and is more powerful and controlled.
Mid/treble is cleaner and clearer, particularly female voices and classical instruments.
Obviously, your hifi system will need to be ‘high resolution’ to hear the full benefits.
Has anyone else noticed this?
I would be interested to hear about the improvements/benefits you have experienced.
5 REPLIES 5
rogeryeung88
Re: Improvements since moving to Plusnet
Nice try Grin
SoFarSoGood
Hi evoGage
As I said, your hifi system will need to be ‘high resolution’ to hear the full benefits.
What part of your HiFi do you think is letting the side down?
Fixes: 365
On mine the wooden needle needs resharpening...I think there's a tool I can buy for that purpose.
Customer and Forum Moderator. Windows 10 Firefox 72.0.2 (64-bit)
Life is tough enough without adding Linux into the mix.
Are you using gold plated fuses for your PC and oxygen free CAT5 cable ?
Fixes: 11
Quote from: SoFarSoGood
Hi all
I Think you will find this will only apply for today
