Impossible objects
Fixes: 4
Impossible objects
Here is an interesting collection of bizarre inventions -
http://www.electronicsweekly.com/blogs/engineering-design-problems/impossible-objects/
Re: Impossible objects
I must have one of those door chains!
Fixes: 102
I like the guitar guitars.....naturally Smiley
Customer and Forum Moderator.
Steve
Seasoned Pro
The Impossible objects #9: Door lock chain maze made me giggle.
If life gives you lemons, make lemonade.
Fixes: 10
Yes I liked that one too! Thats actually a pretty nifty idea for anyone who's paranoid about a burglar trying to put their hand through and undo it.
alanf
10 screws to secure the maze to the door, just two screws to secure the chain to the door frame and a chain that looks a bit thin for anyone needing super-high security.
It would be such a bind putting the chain at the far end of the maze that the temptation would be not to use the chain at all.
I love that calculator, gotta get one of those...!!
