Impossible food!!
Impossible food!!
Let me first say; I don't eat these things...
"Know what I fancy for lunch" said SWMBO "uhmm!!" I responded (fearing the worst) "one of those Tesco ready meals a Cauliflower Cheese" she said.
"Oh ok" I said and off'd to my nearest Tesco to get one for her.
Cooking instructions: Remove cardboard sleeve and film lid. no probs piece of cake....or so I thought.
The sleeve was easy, but the film lid defied all attempts to get it off the rim of the plastic bowl, I eventually stabbed it with a knife and ripped it around inside the rim, inevitably missing a bit that Mrs P attempted to eat.
Anyone got any more examples of difficult packaging?
Fixes: 21
Re: Impossible food!!
Yeah... those prepacked slices of meat.... they have a corner that is supposed to be the place to start ripping open the packaging... but unfortunately, it is cut at the same time as the whole base part, and is almost impossible to get it separated enough to grip...
The other thing is those "pull back" milk sealers... where it has a plasticky filmy tab you have to tear back to lift off... If you suffer from arthiritis or have greasy finger & thumb, or just a weak grip, they are very difficult to remove.
Fixes: 67
They're even worse in Portugal, Milk comes in plastic cartons, the top has a plastic 'ring pull' which removes the seal. Only problem is that on about 50% of the cartons the ring pull just breaks off!. Thenyou have to use a knife to cut out the seal.
Quote from: MisterW
I've had a few of those here.
Can't remember which supermarket they came from.
Quote from: Petlew
Have you noticed all the writing is on the loose outer sleve with nothing on the sealed packing. So my expectation is that all the product is probably brought in from Bulgaria and the BS telling you how wonderful it is and the instructions are written by a marketing type in Guilford who's no knowledge at all  Angry
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Fixes: 9
Some types of medication that come in sealed foil are my main gripe, there is no way you can cut the foil without damaging the package, press too hard and the tablet breaks or shoots across the room, buy a packet of enteric coated Aspirin 75mgs if you want an example.
Products that come in very thick and hard moulded cases are another bugbear of mine, even using a good pair of scissors it takes ages to open them.
Then there are products that once you get the lid off.............there is a second lid to get off.
Fixes: 21
@ PeterLoftus...... probably knows how to spell Guildford though ! ! !  Cheesy Grin
http://www.sweatybetty.com/images/guildford%20sign.JPG
@shtter even if I did I wouldn't admit it  Lips are sealed
Fixes: 21
Ooops... nuther typo.....  Roll eyes Roll eyes Roll eyes
Try taking the cellophane wrapping off an iceberg lettuce Wink
Fixes: 21
or just cut it in half, and keep one half partly wrapped ! ! ...  Cheesy
I have two strapping sons, neither of whom can get on with ring-pulls as fitted to can's of soup etc..
Can't say I'm over keen on them, but use a plastic hook shaped device.
there's a lot to be said for a bench-mounted vice, a lump hammer and a cold chisel.  get into anything with that kit.
The ring pulls on the rectangular tins of sardines. or the twist key to open a tin of corned beef?
Now Zen, but a +Net residue.
Never use them, I always open those sort of cans with a rotary can opener around the edges.
