Image inversion Puzzle
Fixes: 188
I was looking at this post http://community.plus.net/forum/index.php/topic,141789.msg1251436.html#msg1251436
It has an image attached.
Looking at the PNG thumbnail it looked a bit odd until I realised it was upside down with the OR arrow top left.
Clicking it to show the full size JPEG and this was the right way up with the OR arrow bottom right.
I can't recall ever seeing the thumbnail and full images being 180o of each other Huh
Is it just me or do others see this?
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Re: Image inversion
Both stay the same for me.
Fixes: 12
Re: Image inversion
thumbnail is upside down for me
Seasoned Champion
Fixes: 10
Re: Image inversion Puzzle
....and me (FF39)
Fixes: 62
Upside down in Firefox but same way in IE 11
Fixes: 188
I'm using Waterfox.
I've just tried IE11 and both images are upside down i.e OR arrow top left...how strange Undecided
Fixes: 188
I've just had a look at a couple of others and it only happens with this one.....very strange Huh
Inverted here. (chrome + Privacy badger, although disabling it makes no difference)
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Both are upside down in all my browsers.
Fixes: 188
Ghosts in the Machine Undecided
ffox
It's inverted in Edge!
All4One
Firefox thumbnail is upside down. When opening, it's correct way up!
I'm guessing that the photo has been edited to rotate 180 degrees, some photo editing software 'keeps' the original embeded so edits can be reverted and different renderers are reading the original or the edit inconsistently?
Call me 'w23'
g1000
It's to do with EXIF rotation/orientation metadata. The photo was taken on an iPhone, which like a true camera saves the photo 'as the lens sees it' regardless of orientation, in this case the image was taken 'upside down'. The phone uses its orientation sensor to automatically add EXIF metadata to the jpeg on image rotation (in this case rotate 180), which software viewers/browsers commonly read and apply, some programs like Photoshop let you apply it or ignore it. The full image is therefore 'upside down' and should be rotated by the web browser when the metadata is read and applied, though some aren't doing it. The thumbnail (png) cannot contain EXIF data, probably this is generated without applying the rotation.
Fixes: 188
Excellent explanation g100....and a mention to w23 Smiley
Thank you Smiley
