If you`ve received a smartphone or tablet for xmas
2u2me
Re: If you`ve received a smartphone or tablet for xmas
After stating who I used to work for I`m use to taking the blame Smiley
7up
Fixes: 15
@Minivanman wrote:
Well I must be on a different planet @7up
You mentioned about convenience and then revert to my point about choice so sorry, i just don't get it.
No offence but I don't get what you're thinking here either. Whatsapp is convenient because you don't need to signup / create an account etc. It scans your contacts and cross references your phone number with the accounts of your contacts to see who else is on whatsapp - it then automatically keeps your whatsapp contact list updated. This is convenient.
You do however have the choice not to use whatsapp but instead use your default SMS app or another app like skype. That is your CHOICE.
If you don't like the way whatsapp is designed to work then you can CHOOSE not to use it but instead use something else.
I really do not understand what your issue here is.
journeys
@2u2me Glad you posted, it raises the question
"How do you send a text message to a simple mobile phone from a PC or Mac"
Mav
Fixes: 434
It's not exactly sending from the PC but if I connect my phone via the home network I can read, compose, edit and send texts using MyPhoneExplorer on the PC/laptop which is very convenient especially with long texts.
I find that my phone, Galaxy S5 Mini, will change any message that is over 3 messages long into MMS which then gets charged for. This becomes 5 messages when using MPE.
Forum Moderator and Customer
Browni
Aspiring Hero
Fixes: 52
Meanwhile those with older phones are getting cut off at midnight Huh
http://www.dailymail.co.uk/news/article-4078390/Will-cut-WhatsApp-stop-running-MILLIONS-older-phones...
Ex-Plusnetter now living life in the G,fast lane!
Mav
Fixes: 434
According to what I read here many phones would still be able to use WhatsApp after an OS upgrade and Backberry support will continue into mid 2017.
