If You Have A Forum Read This!
Midnight_Caller
Hi All
My Forum is under attack by malishish Hackers, thay are going after the Admin Account, I spotted this in my Forum Error Logs.
The IP Address are:          Attempts to get in:
84.23.49.196                     - 54
170.51.254.202                 - 6
207.249.174.245               - 6
124.42.10.119                   - 6
205.213.195.70                 - 6
So if you do have a Forum keep a eye on your Forum Error Logs.
I have Band the above IP Addresses from my Forum.
Re: If You Have A Forum Read This!
change your admin password several times to foil them.
Midnight_Caller
My admin password is 12 characters long, and that is letters and numbers.
So they are not getting in.
[Edit]
Spelling
Well spotted Gary.  Still may be worth changing your password though Wink
Especially now you have told everyone on this public forum how long your password is.
84.23.49.196 - Whois Information
% This is the RIPE Database query service.
% The objects are in RPSL format.
% The RIPE Database is subject to Terms and Conditions.
% See http://www.ripe.net/db/support/db-terms-conditions.pdf
% Note: This output has been filtered.
%      To receive output for a database update, use the "-B" flag.
% Information related to '84.23.32.0 - 84.23.63.255'
inetnum:      84.23.32.0 - 84.23.63.255
org:          ORG-sL14-RIPE
netname:      RU-IMSYS-20041012
descr:        PROVIDER Local Registry
descr:        Informational-measuring systems Ltd.
country:      RU
admin-c:      VAS20-RIPE
admin-c:      DVZ6-RIPE
tech-c:      VAS20-RIPE
tech-c:      DVZ6-RIPE
status:      ALLOCATED PA
mnt-by:      RIPE-NCC-HM-MNT
mnt-lower:    IMSYS-MNT
mnt-routes:  IMSYS-MNT
source:      RIPE # Filtered
organisation:  ORG-sL14-RIPE
org-name:      Informational-measuring systems Ltd.
org-type:      LIR
address:        "Informational-measuring systems Ltd."
                7 Kominterna str.
                Building 2
                129327 Moscow
                Russian Federation
phone:          +74952157423
fax-no:        +74952157423
e-mail:        admin@imsys.ru
admin-c:        EVK10-RIPE
admin-c:        DVZ6-RIPE
admin-c:        IT247-RIPE
admin-c:        LY10-RIPE
admin-c:        VAS20-RIPE
mnt-ref:        IMSYS-MNT
mnt-ref:        RIPE-NCC-HM-MNT
person:        Vitaly A. Sviridov
address:        IM Systems
address:        Office 16, Raketni blvrd.,
address:        129090, Moscow,
address:        Russia
remarks:        phone:        +7 095 2157423
phone:          +7 495 2157423
remarks:        fax-no:      +7 095 2828404
fax-no:        +7 495 2828404
e-mail:        vsviridov@imsys.ru
nic-hdl:        VAS20-RIPE
mnt-by:        MACOMNET-MNT
remarks:        modified for Russian phone area changes
person:        Dmitry V. Zaharov
address:        IM Systems
address:        Russia
e-mail:        dvz@imsys.ru
nic-hdl:        DVZ6-RIPE
mnt-by:        IMSYS-MNT
% Information related to '84.23.32.0/19AS29319'
route:        84.23.32.0/19
origin:      AS29319
mnt-by:      IMSYS-MNT
David_W
There are several simple ways around unwanted people logging in as admin.
Admin is usually in a folder called /admin so you can use a .htaccess to add a serverside password to that directory, before you even get to the admin.php file, this protects the entire directory.
Look through the scripts and change references to admin.php to my_new_admin_page.php so people can't log in by going to admin.php, the way around that is for them to go to another admin page which will bounce them to the new login page.
Add a redirect script to admin.php, if the script matches your assigned IP's (with wildcards) then it shows the login page, if it doesn't match, it redirects you to the login page for, I dunno, the FBI (if it's a bot, it'll try to log in!)
/edit - quick google found this:
$visitor = $_SERVER['REMOTE_ADDR'];
if (preg_match("/192.168.0.1/",$visitor)) {
header('Location: http://www.thefbi.coml');
} else {
header('Location: http://www.yoursite.com/admin/admin.php');
Changing 192.168.0.1 to the hackers address, I'm sure a PHP guru would tell you how to add multiples or wildcards!
Midnight_Caller
Update From Forum Error Log & Ban List:
84.23.49.196                    - 71 - Update
170.51.254.202                - 6
207.249.174.245              - 6
124.42.10.119                  - 6
205.213.195.70                - 6
213.42.178.199                - 2  - New
This is not new news.  Any server "in the wild" on the internet will have attempts to gain access.
B.
Midnight_Caller
@Baz, Well it has never happened be for, and I have had a forum be for 30-30-2008 what was my ferst back up of the forum.
How do I go about blocking the full of the Union of Soviet Socialist Republics (USSR)?
Fixes: 9
http://www.countryipblocks.net/country-blocks/
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Midnight_Caller
Thanks for the link, but wen I clicked on htaccess deny I got:
Not Found
The requested URL /country-blocks/htaccess-deny-format/ was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Dam, dam.
Fixes: 9
Try from the box at the top right:
# Total Networks: 3,829
# Total Subnets:  32,048,136
deny from 2.92.0.0/14
deny from 62.5.128.0/17
deny from 62.16.32.0/19
deny from 62.16.64.0/19
deny from 62.16.96.0/19
deny from 62.32.64.0/19
deny from 62.33.0.0/16
deny from 62.61.0.0/19
deny from 62.63.64.0/18
deny from 62.64.0.0/19
deny from 62.68.128.0/19
deny from 62.69.0.0/19
deny from 62.76.0.0/16
deny from 62.78.32.0/19
deny from 62.84.96.0/19
deny from 62.89.192.0/18
deny from 62.102.128.0/17
deny from 62.105.0.0/19
deny from 62.105.32.0/19
deny from 62.105.128.0/19
deny from 62.106.96.0/19
deny from 62.109.160.0/19
deny from 62.112.96.0/19
deny from 62.113.32.0/19
deny from 62.113.64.0/18
deny from 62.117.64.0/18
<snipped as it's too long to post>
David_W
Wouldn't it be easier to add an allow from PlusNet IP range, deny from everyone else rule and stick that in a .htaccess in /admin folder?
Midnight_Caller
Short answer is no.
