I've failed....
Fixes: 301
I've failed....
....but maybe you can help?
I keep getting annoying calls from 'Birmingham and Chelsea' school on some automated system telling me my daughter is absent from school, except she doesn't go there and isn't called Mariah.
No amount of Googling has turned up said location of school so I can ring them and correct their mistake.
Anyone got any clue where this school is?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 19
Re: I've failed....
Assume you have tried dialing 1471, to obtain the last number that called you?
other options is the "Telephone Preference Service".... which I believe you have to initiate to stop calls such as thi
http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=25504&s_cid=con_FURL_...
Of course if you are not with BT then you need to make arrangements with your provider !
Just done a google, and it seems there is a "likelyhood" of it being in the USA (Alabama) as the first link is to a Chelsea High School, Birmingham, Alabama...
the third link down gives a further clue.....
Hi We are relocating to Birmingham and we are looking at Springville and Chelsea. It seems both have great schools.
Fixes: 62
Re: I've failed....
deleted - wrong Birminham
Fixes: 301
Re: I've failed....
Sadly it's to my mobile, it's an 0845 number that when googled seems to be used by many a school.
Re: I've failed....
Could be this one;
www.lbhf.gov.uk/Directory/Education_and_Learning/Schools_and_Colleges/Secondary_schools/25811_Hurlin...
with a misheard bit from the automated system?
Mrs Chilly
(after threats from hubby to not pretend to be him, think he may be embarrased by my lack of technical skills!)
Fixes: 19
Re: I've failed....
Quote from: chillypenguin
Yes, Indeedy !... especially as, probably, 90% of people have never heard of Hurlingham, and on a mobile it could very well sound like Birmingham. !    Undecided
Well Done  Mrs Chilly !  Cheesy
nadger
Re: I've failed....
Quote from: shutter
Very posh
Re: I've failed....
My kids' school also has this.  It's quite a good system, but only as good as the school's phone records clearly.  Aside from letting you know if they've bunked off, you can get reminders about none pupil days, school closed due to fire, flood, snow, etc.
Is it worth trying entering the number here http://www.saynoto0870.com/search.php
Fixes: 301
Re: I've failed....
Thanks Mrs Chilly, that's great. I shall call them tomorrow Smiley
Fixes: 158
Re: I've failed....
Keep us posted Smiley
Customer and Forum Moderator. Windows 10 Firefox 63.0 (64-bit)
Fixes: 19
Re: I've failed....
Yeah!.... but don`t phone us !  Cheesy
Fixes: 301
Re: I've failed....
Indeed that was the right school and bizarrely I could now have all Mariah's phone numbers and parents phone numbers if I'd have written them down...
They have now removed my number which was a number they had with an extra digit on the end, so that should be the last of it.
Thanks again Mrs Chilly Smiley
Fixes: 19
Re: I've failed....
A good result then..... perhaps Mrs Chilly, should have her own avatar, and join in the forums in her own right..... well qualified, methinks !  Smiley
Re: I've failed....
Oh yes, Josie and Poppy could use some reinforcements.
Fixes: 158
Re: I've failed....
Ooooo....I don't know about that Shocked
