I made a spectacle of myself :P
This time,
I have ended up with Silk emulsion splatters, on my glasses,
Silly me forgot to take my glasses off when doing the 1st coat
What do you find is the best way to clean paint off of glasses
I use MGFL (Mild Green Fairy LipSquid)
& then for future reference
For gloss paint ?Huh
12 REPLIES 12
Re: I made a spectacle of myself :P
White spirit but wipe it on and off, never let it dry and impregnate any lens to frame spacers if you have any or the fumes will go for your eyes obviously
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
If it's dry I just crack it off with me thumb nail!  Cool
Geoff,
York.
depends on the lens coating but normally lint free cloth, remove lens from frame and use the alcohol based lens cleaner fluid before reassembling them, normally though I wear goggles or a face shield visor so I don't end up looking like Mr Blobby  Wink
Fixes: 14
Safety goggles... £1.14 from B&Q and you didn't get any?  Shocked
Got some, however, rarely use them for painting, unless spray painting
Fixes: 14
More fool you then eh?!
Mind you.. that said i had work gloves on and still ended up nearly going through a finger last week  Roll_eyes
What was you doing, by putting your finger in the way ?Huh
Fixes: 14
I didn't put it in the way... the power tool decided to escape my firm grip and go hunting. I should have learnt from the first time when I was under the car, it shot off, danced around the floor and then stopped right next to my head  Shocked
Did I learn? Did I ****!
No sir, instead i carried on... the next time it went for the knuckle  Crazy
Fixes: 41
About time you got rid of it then..... as it seems to want to take you out, every time you take it out  Cheesy
Hence the battle of the
Power Tool V's the Human Continues Tongue
It appears that it is not only power tools that are @ war with us Humans
[quote= i100.independent.co.uk/article/a-piece-of-fibreglass-went-right-through-this-mans-finger--xkhujA-FQx]
Despite the splinter piercing a tendon, StreetfighterXD said he didn’t feel any pain.
The shard was removed under local anaesthetic and had to be taken out the long way too because tiny little spikes were preventing it from going back out the way it came. Ouch!
Fixes: 14
I also didn't feel any pain when the power tool had me. Next day I damn well did though  Crazy
