I didn't know that!
I didn't know that!
As a life long collector of useless information (is there a name that's printable for that?) I quite often tune into the Sky Discovery channel's "How do they do that" and "How it works" which are usually 10 minute quickies of assorted points of interest, most of which have been repeated many times.
A day or so ago a programme on how glass is made (that I hadn't seen before) was showing. I only had half an eye on it as the subject has been covered many times by other programmes, and anyway the process is quite well known.
Then suddenly the presenter said that; chemically glass is actually a liquid! indeed if it wasn't liquid we wouldn't be able to see through it. Indeed panes of glass left to their own devices over long periods of time creep downwards under their own weight, making them measurably thicker at the bottom than it was when it was installed...
I didn't know that.
Fixes: 10
Re: I didn't know that!
I did (proves I'm another collector of useless information).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Comes with the "bright spark" status jelv.
itsme
Is glass liquid or solid?
It is sometimes said that glass in very old churches is thicker at the bottom than at the top because glass is a liquid, and so over several centuries it has flowed towards the bottom.  This is not true.  In Mediaeval times panes of glass were often made by the Crown glass process.  A lump of molten glass was rolled, blown, expanded, flattened and finally spun into a disc before being cut into panes.  The sheets were thicker towards the edge of the disc and were usually installed with the heavier side at the bottom.  Other techniques of forming glass panes have been used but it is only the relatively recent float glass processes which have produced good quality flat sheets of glass.
There is no clear answer to the question "Is glass solid or liquid?".  In terms of molecular dynamics and thermodynamics it is possible to justify various different views that it is a highly viscous liquid, an amorphous solid, or simply that glass is another state of matter that is neither liquid nor solid.  The difference is semantic.
Gee thanks itsme!!
Quote from: itsme
Uhmm!!
Quote from: Petlew
I didn't know that.
Thanks Petlew I didn't know that either.  Now how can I bring that up in conversation Undecided
Don't hang on to that glass of Merlot too long it may change shape in your hand...
That would be a pane Wink
Now where will this lead?
Roll eyes
I see a glazed look coming over you Be3G.
Maybe he's shattered Wink
Or framed...
itsme
Quote from: Petlew
Quote from: itsme
Uhmm!!
There is a clear answer. If glass is a liquid what is the freezing point?
