How to......
- General Chat
- How to......
How to......
19-04-2018 8:11 AM - edited 19-04-2018 8:13 AM
Has anybody tried cutting corrugated bitumen sheeting?
I've just bought some to re-cover my wood store but I need to cut and turn them so the rain runs off the right way as the sheets are too long. Tried cutting one yesterday which was easy enough, but the saw blade just keeps getting clogged with bitumen so that it sticks and snags. Only thing I can thing of trying now is cutting with a pair of sheet metal shears.
Plenty on YouTube on how to fix, but nothing found so far on the best way to cut them, so while I mull it over I'm going to rummage through my shed and try and find those shears. It's a nightmare of mess in there!
Compare yourself to who you were yesterday, not who somebody else is today
Re: How to......
19-04-2018 8:32 AM - edited 19-04-2018 8:38 AM
Try using a normal woodworking cross-cut saw.... but... see if spraying the sides of the blades with WD40 eases the situation when cutting... it should, lubricate and soften the debris.
If you havent`t got wd 40... try some furniture polish spray...
Re: How to......
19-04-2018 8:33 AM
According to a manufacturers installation guide:
If cutting is necessary, cut Coroline sheets to length using a hand saw with a lubricating spray on the blade.
From: ww.arielplastics.com/~/media/Ariel-Plastics/Files/Installation-Guides/Coroline_Installation_Guide.pdf
Re: How to......
19-04-2018 9:51 AM
Yep, that's done it guys. Thanks
Re: How to......
20-04-2018 3:06 PM - edited 20-04-2018 3:34 PM
Those sheets now cut and fixed, just need to order some wood for next winter.
Where's my £200 fuel allowance?
PS. WD40 worked perfectly, cleaned saw after each cut and easy-peasy.
Re: How to......
20-04-2018 3:13 PM
@Minivanman glad to be of help ! ! ..
Re: How to......
20-04-2018 5:04 PM
A better view of the finished product and hopefully, no wet wood next winter!
Re: How to......
21-04-2018 6:42 PM
It looks as if you've made a decent job of it. If you lived in Sheffield I doubt you'd have a problem stocking it up!
