How to bring traffic to a standstill in one easy lesson
Fixes: 62
Fixes: 188
Re: How to bring traffic to a standstill in one easy lesson
It helps to have no brain and a very thick skin when 'organising' such events Crazy
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
They did the same thing in our area with similar problems as it was the main road for people going to work so it made 90% of the local workforce late for work. This was great as 50% work at the local hospital so if you were ill that day it was tough luck.
Another good idea gone wrong
pierre_pierre
I had fun with one of those years ago, we were doing a local circuit for test purposes and went through the check several times.
Conversation.
Where have you just come from - Boreham
Where are you going to  - Boreham
no what are you doing - going from Boreham to Boreham
Then go back and have another go at them  Cheesy Cheesy Cheesy Cheesy Cheesy
How often do you make this journey sir?
I make this journey just the once, but I've made other similar journeys in the past. I imagine I may make similar journeys in the future.
And is it just me, or do they always look a little upset when they ask you how much money you earn in a job where you can be on your way home mid-afternoon and then they realise that they have been stood in the rain all day, for far less than that.
