How good can a virgin be?
Fixes: 13
Well,... I am not really into cooking, so don`t understand a lot of the stuff, and terms, they use on these cooking programs....
Jus?  what`s that?  is it a posh/cooking snob/foodie  name for gravy ?
Balsamic Vinegar?  Huh?  where is Balsam?  I`ve heard of Balham, in London.
and the point of my question....
Extra virgin oil..... surely you can`t be more pure and straight than an "ordinary" virgin....
or is that the point....( like Jus. )  .. just a posh/cooking snob/foodie  way of saying... "bung some olive oil in it instead of fat to make it slide down easier"...
Fixes: 60
Re: How good can a virgin be?
I wish I hadn't checked http://answers.yahoo.com/question/index?qid=20080120082944AAlhnZh
What is ‘Virgin?’ Virgin means mechanical extraction. The oil or juice is extracted by machines with no chemicals used in the process.
What is ‘Extra’? Mechanically extracted (virgin) olive oil is not all the same quality. 'Extra' is the highest quality and is thus classified because it goes through a battery of tests, both laboratory (analytical) as well as 'taste' (an olive oil master tastes the way wines are taste tested). Virgin olive oil that is judged to have ‘no defects’ is classified as extra. So ‘extra virgin’ means – mechanically extracted olive juice that passes laboratory and taste testing with no defects.
http://en.wikipedia.org/wiki/Olive_oil
Extra-virgin olive oil Comes from virgin oil production only, and is of higher quality: amongst other things, it contains no more than 0.8% free acidity (see below), and is judged to have a superior taste, having some fruitiness and no defined sensory defects. Extra-virgin olive oil accounts for less than 10% of oil in many producing countries; the percentage is far higher in the Mediterranean countries (Greece: 80%, Italy: 65%, Spain 30%).
Virgin olive oil Comes from virgin oil production only, but is of slightly lower quality, with free acidity of up to 1.5%, and is judged to have a good taste.
Regardiong Balsamic Vinegar - http://en.wikipedia.org/wiki/Balsamic_vinegar which shows how manufacturing methods degrade over the years
Now back to the usual facetious posts
Grin Grin
Misleading title....
Was going to say a virgin can be good but you can teach them to be naughty!  Cheesy
I think virgin olive oil is the first pressing of the season. Extra virgin is the first pressing from New trees.  If I'm wrong I'm sure someone will correct me.  Smiley
There you go -----I was totally wrong  Angry
From a keen cooks point of view, the extra virgin oil has a nice peppery taste while the lower quality "normal" olive oil had a more mellow taste.
I use the extra virgin for adding to my pizza dough and sauce while I use the cheaper stuff for light frying duties.
I remember buying a small bottle of £30 Extra Virgin olive oil once - it went through the till at £2 which was even better  Grin It was amazingly light and tasty and you could just sit there dipping fresh bread into it with a little balsamic vinegar.
Fixes: 13
So,..... if Cheddar cheese comes from Cheddar..... and Leicester Red... from Leicester....
Where is Balsam? where the vinegar comes from Huh?
It's a lot better than the days when in the UK you only came across Olive Oil as a clear liquid which you purchased from the chemist's to soften wax in your ears. Food in the UK in the 60's used to be a lot more boring and unhealthy.
Now Zen, but a +Net residue.
Quote from: shutter
The word balsamico (from Latin balsamum, from Greek βάλσαμον) means "balsam-like" in the sense of "restorative" or "curative"
Fixes: 13
So,  you could use it like a medicine then to cure all sorts of maladies !  ( like extra vigins ! ! ! 0.  Shocked
Fixes: 142
I thought virgin olive oil was simply that which hadn't been used before (recycled) and extra virgin was just a bigger bottle Cheesy
Forum Moderator and Customer
Fixes: 13
Yeah,... me too !... hence my posting....  Cheesy
thejudge
"Extra virgin oil"
Just means that you can keep it on the shelf for longer...  Grin
RichAllen
You can have all the Olive Oil you want, but she'd never leave Popeye!
Er, yeh...
*gets coat*
