How do you do that?
How do you do that?
Like most correspondents here I occasionally use the "quote" facility. But how do you add multiple quotes? I don't have a particular reason to do so at this time, just wondered how it was done.
Fixes: 224
Re: How do you do that?
In the full post (as opposed to quick reply) there is a quote button, use that and just copy and paste what you want into between [ quote] [/quote ]
so..
and
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
pierre_pierre
and you can stack tem one inside the other
and
Fixes: 10
IF you're also looknig to quote various replies, then in the reply screen/page if you scroll down and look at the replies listed in reverse order you'll see that on the right hand side there is a link saying 'Insert quote'.
Go ahead, try replying to this and then have a look below the text box at all the other replies posted and you'll see what I mean  Wink
Doh! thanks guy's, easy when you know how, especially the one about looking at the list of replies below...how dim can you get!!
Fixes: 224
no comment Tongue
Oi!!
Lurker
From the chap with the dimmest Avatar...
Well pointed out, I feel better now!!
Couple of points:
One is to bear in mind that whilst nested quotes are useful, they should be used with some restraint as they start to look confusing very quickly; generally speaking, if you're going beyond one nested level you're probably going over the top.
The other is to expand on okrzynska's method. One thing not mentioned thus far is the fact that when you do things that way (or by initiating a reply by clicking on a post's ‘quote’ button), you also attach some additional header data to the quote, which makes the post from which it originates easier to track down. For example:
Oi!!
Quote from: Petlew
Oi!!
Spot the difference. Smiley
Fixes: 10
The extra information not only makes it easier to track down, but is a clickable link to the quoted post!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
…which is how it's made easier to track down. Tongue
