Help!!
petlew
Help!!
Whilst sealing an envelope on my laptop key board I have managed to press a combination of keyboard shortcut and inverted the entire screen image top to bottom, left to right. Not only is this incredibly difficult to work with I’m not a user of shortcuts, and don’t know the way to get the screen back to normal view again.
Help please.
14 REPLIES 14
shutter
Fixes: 47
Re: Help!!
Move to Australia !?!?!?!?
Cheesy
petlew
Re: Help!!
Well, I’m off to New Zealand in December, but I’d rather have this fixed before that if possible.
petlew
Re: Help!!
Suppose I should mention I’m not using the laptop for this topic!!!
Re: Help!!
shutter
Fixes: 47
Re: Help!!
You could try something like this ......
Maybe use a smaller mirror, so you can fix it easier, and still use the keyboard ! !
picbits
Re: Help!!
Ctrl + Alt + One of the arrow buttons on the keyboard (I can't remember which !)
shutter
Fixes: 47
Re: Help!!
@picbits See mooks post above
@Anonymous  Nice one !
petlew
Re: Help!!
Thank you picbits, that fixed it. It is the up/down arrows depending on which ways you want to go.
petlew
Re: Help!!
Yes, and thank you Mook, I saw picbits fix first.
Champnet
Champion
Fixes: 7
Re: Help!!
A stunt often pulled by the young bucks in the office. If I got called in I’d just turn the screen over and walk away. Easier to do with the old CRT screens.
petlew
Re: Help!!
One thing I was really surprised at, was just how difficult it was to try and coordinate a mouse around the screen when its upside down, it goes against everything you normally take for granted. Would left-handers have the same problems I wonder.
shutter
Fixes: 47
Re: Help!!
Shudda gon to specsavers ! ! ....   or used the mouse in reverse ( upside down ).  Smiley
picbits
Re: Help!!
I have this issue a lot as we work with multiscreen monitors which are often rotated - I'm currently working on retrofitting a 32" 4K monitor in a 19" rack mount rotated 90 degrees - not sure if it will work but could be interesting.
Strat
Fixes: 505
Re: Help!!
When I'm gaming I have the 'look up/look down' setting reversed so push stick forwards to look down.
The default in virtually all games I have played is the reverse of this.
I spent a lot of time playing flight sim where in a plane you push the stick forwards to dive and backwards to climb.
If I try to play on my grandson's PS4 it's difficult to say the least.
I have had the upside down screen trick played on me and I really had to concentrate to reverse the setting.
Customer and Forum Moderator. Windows 10 Firefox 88.0.1 (64-bit)
