Heat loss
- General Chat
- Heat loss
Heat loss
21-03-2016 12:11 PM
Any other ideas on how I might check heat loss would be useful
Re: Heat loss
21-03-2016 12:15 PM
You could also approach the problem from the 'other end' and try measuring inside surface temperatures to find 'cold spots', any electronic thermometer with a surface temperature probe should suffice for this.
Or possibly one of these might allow you to do a 'survey' inside and out.
[Edit] found this if anyone wants to get into thermal imaging at a (comparatively) reasonable cost.
Re: Heat loss
21-03-2016 12:39 PM
Re: Heat loss
21-03-2016 2:59 PM
We recently had these replaced but even with new seals there is no guarantee they are ok but I have ordered a item identified by Mav which will allow me to check them.
@Mav,
Thanks for the links, the feedback on the item from Maplin sounds right up my street at £19.99 and it comes with free postage.
I can see a few other useful uses for this item.
The professional ones for hire are likely to be much better but the cost of hiring one is a bit above my budget.
Thanks for the responses.
Re: Heat loss
21-03-2016 3:17 PM
Quote from: gleneagles @Mav,
It was w23
Forum Moderator and Customer
Re: Heat loss
21-03-2016 5:17 PM
@w23
Apologies,
Next visit to specsavers is due shortly.
Re: Heat loss
21-03-2016 6:18 PM
I use it for measuring the temperatures in suspect motors, brake units, batteries etc.
It's a decent bit of kit for the price.
Re: Heat loss
21-03-2016 6:37 PM
Re: Heat loss
21-03-2016 6:46 PM
Re: Heat loss
22-03-2016 4:19 PM
Quote from: gleneagles Despite taking the usual measures I am convinced our house is a lot colder than it should be and I wondered if it was possible to either hire or get access to a thermal image camera.
How is it constructed? Solid brick external walls, or cavity, and how old is it?
Re: Heat loss
22-03-2016 5:24 PM
Built 1987, cavity walls with some sort of insulation which look like small polythene balls.
I am a bit suspicious about the floor, which is a solid ? bitumen floor and a number of years ago I put down some laminated floor boards with a carpet square in the middle, should that turn out to be the problem then I am stuck as the only answer would be to put a fitted carpet down which defeats the object of a laminated floor.
Hopefully the item ordered from Maplin with confirm that one way or another.
Re: Heat loss
22-03-2016 6:28 PM
Re: Heat loss
22-03-2016 6:39 PM
Do, please, let us know how you get on.
How much insulation do you have in your loft? Often well worth topping up if less than about 10 inches.
