Have you seen my Garden...... I wish.
Infinity
Is this Britain's most immaculate garden?
Pensioner spends 30 HOURS A WEEK tending his lawn which is cut to exactly 5mm
http://www.dailymail.co.uk/news/article-2395771/Is-Britains-immaculate-garden-Pensioner-spends-30-HO...
Re: Have you seen my Garden...... I wish.
Well, if it gives them pleasure then so be it!  Wink
Geoff,
York.
Until recently he must have spent another 30 hours a week watering it.
Infinity
I've just done a SMART check, I appear to spend 30+ hours a week on my computer  !!!
Fixes: 50
She's 37 and he's 39...gardening is an ageing process.
Customer and Forum Moderator.
Thunderclap
That's what you get when you've OCD as a OAP - very neat borders.
But is that Astroturf they're using? Otherwise those lawn edges need cutting with small scissors.
The shrubs do need a slight trim though and, the fencing needs painting.
Fixes: 9
Quote from: PlusComUK
I must do at least 10 hours a day...
Roberto0151
I think they are just a little bit potty. Our grass (can't call it lawn) is rough but Swmbo and I manage the veg patch and greenhouse to provide - via the freezer- the vast majority of our own fruit and veg.
I think that's far more important thn trying to keep up with the Joneses. Smiley
Fixes: 9
Can only assume this guy never goes on holiday ? Leave a garden like that for 2 weeks and it would take some time to get it up to scratch again.
According to the newspaper he cuts the grass several times a day........ how do you do that when it's raining for several days on the run AND it's not good to walk on a wet lawn as it compacts the soil. (or so they tell me)
Quote from: gleneagles
Must drive their nearest neighbours mad.
Our bowls green is cut twice a week and that's 3mm after cutting. Shouldn't think he gets much off it cutting several times a day, just making sure the stripes don't fade.
